Einleitung
Use this guide to remove and replace the back cover of your Toshiba Satellite C55D-A5108. The back cover provides security to the inner components of your laptop, while also providing grip and helping prevent overheating.
This guide will remove the back cover of your laptop, the battery, and hard drive. You will also be putting the components back together. If you do not feel confident with doing this yourself, please find someone that can help you with the process.
Was du brauchst
Hold the left notch in an unlocked position with one hand and use the other hand to slide the battery out.
Grasp the side of the hard drive opposite the circular battery, and carefully pull out the drive by moving it away from the circular battery.
Remove the 16 screws holding the back cover with a Phillips #0 screwdriver.
Pry the cover off with an opening tool.
Gently remove the cover with your hands and place to the side.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
