Zum Hauptinhalt wechseln
Toshiba Satellite E45-B4200 Heat Sink Replacement
Was du brauchst
  1. Toshiba Satellite E45-B4200 Heat Sink Replacement, Back Case: Schritt 1, Bild 1 von 3 Toshiba Satellite E45-B4200 Heat Sink Replacement, Back Case: Schritt 1, Bild 2 von 3 Toshiba Satellite E45-B4200 Heat Sink Replacement, Back Case: Schritt 1, Bild 3 von 3
    • Make sure to turn off the device, remove the battery, and unplug the laptop from the charger prior to the disassembly.
    • Use a Phillips #0 screwdriver to remove fourteen 3.75 mm screws from the back cover.
    • Use a spudger or opening tool to gently separate the back cover from the top of the device. Work your way around the perimeter of the laptop and undo the clips with the spudger.
    • Remove the back case.
  2. Toshiba Satellite E45-B4200 Heat Sink Replacement, Heat Sink: Schritt 2, Bild 1 von 1
    • Locate the heat sink system in the middle of the motherboard, resembling a copper strip.
  3. Toshiba Satellite E45-B4200 Heat Sink Replacement: Schritt 3, Bild 1 von 1
    • Using a #0 Phillips screwdriver, unscrew the heat sink attached to the processor.
    • This is located at the center of the motherboard.
  4. Toshiba Satellite E45-B4200 Heat Sink Replacement: Schritt 4, Bild 1 von 1
    • Lift the heat sink system off the processor.
    • Apply fresh thermal paste to the CPU before placing a new heatsink in the device.
Abschluss
Raymond Makynen
289 Reputation
3 Anleitungen geschrieben
UMass Dartmouth, Team 5-2, Ramos Spring 2023 Mitglied von UMass Dartmouth, Team 5-2, Ramos Spring 2023
UMASSD-RAMOS-S23S5G2
3 Mitglieder
6 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 3
Letzte 30 Tage: 4
Insgesamt: 120
