Einleitung
A broken touchpad is annoying on any laptop. Sometimes this is an easy fix. Use this guide to fix a disconnected touchpad on your Toshiba Satellite P755 S5390.
Was du brauchst
Close the cover and turn the laptop over so that the spine is facing away from you.
Slide and hold the locks on both sides of the battery to the unlocked position.
Slide and lift the battery out of its compartment.
Use the Philips #1 screwdriver to remove the 15 screws from the base of the laptop.
Using either the iFixit opening tool or your hands, gently remove the keyboard from the base panel.
Check if the touch pad cable is plugged into the ZIF connector on the motherboard.
Grab the blue plastic above the touch pad wire.
Firmly plug the cable into its socket on the motherboard.
If you need information on how to remove or replace connectors take a look at the Recognizing and Disconnecting Cable Connectors guide.
5 weitere Nutzer:innen haben diese Anleitung absolviert.
