Zum Hauptinhalt wechseln
Toshiba Satellite U840W 12V Charging Port Replacement
Was du brauchst
  1. Toshiba Satellite U840W 12V Charging Port Replacement, Toshiba Satellite U840W Disassembly Guide: Schritt 1, Bild 1 von 2 Toshiba Satellite U840W 12V Charging Port Replacement, Toshiba Satellite U840W Disassembly Guide: Schritt 1, Bild 2 von 2
    • There are ten 5mm screws surrounding the edge of the cover.
    • A rubber cap covers the eleventh 5mm screw (in the center).
    • Remove the screws using a Phillips #00 screwdriver.
  2. Toshiba Satellite U840W 12V Charging Port Replacement: Schritt 2, Bild 1 von 3 Toshiba Satellite U840W 12V Charging Port Replacement: Schritt 2, Bild 2 von 3 Toshiba Satellite U840W 12V Charging Port Replacement: Schritt 2, Bild 3 von 3
    • Pry between the casing and cover using a plastic wedge tool.
    • Use the wedge tool to move along the case & slowly pry it open.
    • The wire for the 12v charging port connects the cover to the casing.
  3. Toshiba Satellite U840W 12V Charging Port Replacement: Schritt 3, Bild 1 von 3 Toshiba Satellite U840W 12V Charging Port Replacement: Schritt 3, Bild 2 von 3 Toshiba Satellite U840W 12V Charging Port Replacement: Schritt 3, Bild 3 von 3
    • Disconnect this connector from the motherboard to avoid damaging the motherboard or charging port cable.
  4. Toshiba Satellite U840W 12V Charging Port Replacement: Schritt 4, Bild 1 von 1
    • Disconnect the battery.
    • Hold down the power button for ~10 seconds to discharge any stored electricity from the motherboard.
  5. Toshiba Satellite U840W 12V Charging Port Replacement, 12V Charging Port: Schritt 6, Bild 1 von 1
    • Remove the connector from the motherboard.
    • This separates the only connection from the motherboard to the cover.
  6. Toshiba Satellite U840W 12V Charging Port Replacement: Schritt 7, Bild 1 von 1
    • Remove the screw holding 12v charging port to the cover.
  7. Toshiba Satellite U840W 12V Charging Port Replacement: Schritt 8, Bild 1 von 1
    • Remove the 12v charging port from the cover.
Abschluss
2 weitere Nutzer:innen haben diese Anleitung absolviert.
Gateway, Team S1-G1, Saknee Spring 2019 Mitglied von Gateway, Team S1-G1, Saknee Spring 2019
GCC-SAKNEE-S19S1G1
4 Mitglieder
5 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 3
Letzte 30 Tage: 8
Insgesamt: 252
