Einleitung
- The motherboard of a laptop is a vital piece of your computer, if you find that the performance or functionality of your device is limited, then it may be time for the part to be replaced.
- If you are positive that the motherboard of your Toshiba Tecra z50-a is damaged or causing issues, then it’s time for it to be replaced. Follow this guide to learn how to replace the motherboard of the laptop.
- Before disassembling the laptop, ensure it is powered off and nothing is plugged into the device.
- Remove any rings, bracelets, or any other metal objects from your hands.
Was du brauchst
Turn off the laptop.
Flip the laptop over so the bottom is facing upwards and the hinges are closest to you.
Remove the fifteen 5 mm screws from the back panel using a Phillips #0 screwdriver.
Pull the wired cable up towards the top of the laptop to disconnect it from its socket on the motherboard.
Remove the single 2 mm screw from the corner of the laptop using a Phillips #0 screwdriver.
Remove the four 3 mm screws from the heat sink using a Phillips #0 screwdriver.
Pull towards the bottom of the laptop to disconnect the fan cable from its connector on the motherboard.
Lift up on plastic covering over the Wi-Fi card.
Disconnect the black and white coaxial cables from the Wi-Fi card.
Lift up on the black retaining flap using a pair of tweezers.
Grab the middle of the motherboard with your hands and lift up to remove it from the laptop.
Eine weitere Person hat diese Anleitung absolviert.
