Zum Hauptinhalt wechseln
Trek FX2 Fitness Bike Saddle Replacement
Was du brauchst
  1. Trek FX2 Fitness Bike Saddle Replacement, Saddle: Schritt 1, Bild 1 von 3 Trek FX2 Fitness Bike Saddle Replacement, Saddle: Schritt 1, Bild 2 von 3 Trek FX2 Fitness Bike Saddle Replacement, Saddle: Schritt 1, Bild 3 von 3
    • Locate the bolt under the saddle.
    • Use a 5mm Allen Wrench to loosen and remove the M8x30 mm bolt.
    • Remove the saddle from under the plate.
  2. Trek FX2 Fitness Bike Saddle Replacement: Schritt 2, Bild 1 von 2 Trek FX2 Fitness Bike Saddle Replacement: Schritt 2, Bild 2 von 2
    • Use a towel covered in isopropyl rubbing alcohol to clean any dirt from the bolts and plate.
  3. Trek FX2 Fitness Bike Saddle Replacement: Schritt 3, Bild 1 von 2 Trek FX2 Fitness Bike Saddle Replacement: Schritt 3, Bild 2 von 2
    • Apply Finish Line Premium Grease to the bolt.
    • Work the grease around the threads.
  4. Trek FX2 Fitness Bike Saddle Replacement: Schritt 4, Bild 1 von 3 Trek FX2 Fitness Bike Saddle Replacement: Schritt 4, Bild 2 von 3 Trek FX2 Fitness Bike Saddle Replacement: Schritt 4, Bild 3 von 3
    • Clean the replacement bicycle saddle with a towel and isopropyl alcohol.
  5. Trek FX2 Fitness Bike Saddle Replacement: Schritt 5, Bild 1 von 2 Trek FX2 Fitness Bike Saddle Replacement: Schritt 5, Bild 2 von 2
    • Apply Finish Line Premium Grease to the rails of the bicycle saddle.
  6. Trek FX2 Fitness Bike Saddle Replacement: Schritt 6, Bild 1 von 3 Trek FX2 Fitness Bike Saddle Replacement: Schritt 6, Bild 2 von 3 Trek FX2 Fitness Bike Saddle Replacement: Schritt 6, Bild 3 von 3
    • Align the seat rails with the channels in the saddle plate.
    • Slide the rails into the channels of the saddle plate.
    • Adjust the seat position to your preference.
  7. Trek FX2 Fitness Bike Saddle Replacement: Schritt 7, Bild 1 von 3 Trek FX2 Fitness Bike Saddle Replacement: Schritt 7, Bild 2 von 3 Trek FX2 Fitness Bike Saddle Replacement: Schritt 7, Bild 3 von 3
    • Insert the bolts into the holes on the saddle plate.
    • Tighten the bolts by hand until they are snug.
    • Use an Allen wrench to evenly tighten the bolts.
  8. Trek FX2 Fitness Bike Saddle Replacement: Schritt 8, Bild 1 von 1
    • Sit on the seat to check its angle and stability.
Abschluss
Test out the bike seat, and adjust accordingly.
David Fong
157 Reputation
1 Anleitung geschrieben
UC Davis, Team 4-6, Vidal-Chiesa Fall 2024 Mitglied von UC Davis, Team 4-6, Vidal-Chiesa Fall 2024
UCD-VIDAL-CHIESA-F24S4G6
3 Mitglieder
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 17
Insgesamt: 89
