Einleitung
if your tablet suffered water damage and/or no longer functions properly, replacing the motherboard might be necessary.
Was du brauchst
Insert a plastic opening tool between the back panel and the front of the tablet, and gently pry it away from the tablet.
Using a #000 screwdriver, unscrew the 5 screws connecting the motherboard to the device.
Using a soldering tool, melt the two metal parts connecting the battery wires to the motherboard.
Using a #000 screwdriver, unscrew the three 3 mm screws that fasten the smaller segment of the motherboard to the tablet.
Using a soldering tool, melt the six metal connections located towards the bottom of the tablet.
Ein Kommentar
My grandma owns the 4G model and someone broke the volume down button. because of this the volume goes down on its own or the device goes into recovery mode. It actually reset it self by doing this but there is no use in me setting it back up just for it to be reset again. Any help you be great.
