Einleitung
If the battery on your Trio Stealth-10 is no longer functioning, replacement isn't difficult and this guide will give you the step by step procedure to do so.
Was du brauchst
To remove the back panel, you will need to use a plastic opening tool and slowly separate the back panel from the device.
In diesem Schritt verwendetes Werkzeug:Tweezers$4.99
Disconnect the screen/digitizer connection. Use tweezers and pull each grey end of the connection until there is a small gap between the grey and white on the connector to the motherboard. The connection should be easily removable.
Pull the cable away and clear from under the battery to avoid damage to the connection.
Pry battery up from adhesive. Use a type of adhesive remover. Nail polish remover works well.
6 weitere Personen haben diese Anleitung absolviert.
