Einleitung
If the screen/digitizer on your Trio Stealth-10 is no longer functioning, replacement isn't difficult and this guide will give you the step by step procedure to do so.
Was du brauchst
To remove the back panel, you will need to use a plastic opening tool and slowly separate the back panel from the device.
Disconnect the screen/digitizer connection. Use tweezers and pull each grey end of the connection until there is a small gap between the grey and white on the connector to the motherboard. The connection should be easily removable.
Pull the cable away and clear from under the battery to avoid damage to the connection.
Pry battery up from adhesive. Use a type of adhesive remover. Nail polish remover works well.
Next you must solder off the wires that connect the speaker to the motherboard.
Next you will need to remove the two screws attached to the speaker. If you have a 54 bit Driver Kit use the Philips Head 0 (or PH 0) head to remove the two 4mm screws.
Next use your PH 0 to remove the two 4mm screws to detach the camera support fixture.
Disconnect the camera from the mother board. Use a spudger and lift the grey latch until it is facing up then pull out the connection for the cameras.
Remove the second layer of tape above camera cable connection gently and remove the cameras from the device.
Use your spudger to disconnect the screen/digitizer connection from the motherboard.
Use a pair of tweezers to grasp the screen/digitizer connection gently and remove each accordingly.
Grasp the EDC tape with your tweezers and lift it off gently from the motherboard and set aside to be reused.
Be sure that all the connections to the motherboard are disconnected. Proceed to remove the motherboard by slowly tilting it away from you and then lifting it straight up.
Remove all disconnected components and remove screen/digitizer.
3 weitere Personen haben diese Anleitung absolviert.
