Einleitung
The Turtle Beach P11 headset is equipped with two 50 mm diameter speakers with a frequency response between 20 Hz to 20 kHz which is same as the audible frequency range of the human ear. They have a bass boost fixed at +6 dB range at 50 Hz. There could be problems with the speaker such as inaudibility, crackling voice, distorted sounds etc. which cannot be fixed by suggested technical methods and thus require replacement of the speakers.
Was du brauchst
Now slowly pull down the ear cushion as it completely separates from the speaker.
4 weitere Nutzer:innen haben diese Anleitung absolviert.
6 Kommentare
I am sorry jtrent238 , but i can further guide you on how you could solve the problem
Do you know where I can get the speakers from?
my problem exist in this area https://imgur.com/grLwOkt cant figure out how to detach the entire bud to get access to the internal wires
