Zum Hauptinhalt wechseln
Turtle Beach Elite 800 Audio Board Replacement
Was du brauchst
  1. Turtle Beach Elite 800 Audio Board Replacement, Ear Cushion: Schritt 1, Bild 1 von 2 Turtle Beach Elite 800 Audio Board Replacement, Ear Cushion: Schritt 1, Bild 2 von 2
    • To remove the ear cushions, press firmly down and rotate them clockwise, it should twist about 2mm and release, allowing you to pull it off.
    • When reassembling, be sure to line up the locking plates.
  2. Turtle Beach Elite 800 Audio Board Replacement, Audio Board: Schritt 2, Bild 1 von 2 Turtle Beach Elite 800 Audio Board Replacement, Audio Board: Schritt 2, Bild 2 von 2
    • Remove the screws (9.47 mm Phillips head) from the blue plating on the headset to reveal the inside.
  3. Turtle Beach Elite 800 Audio Board Replacement: Schritt 3, Bild 1 von 2 Turtle Beach Elite 800 Audio Board Replacement: Schritt 3, Bild 2 von 2
    • If you are working on the LEFT side ear, you will first have to detach the battery by gently unplugging the white plug on the top of the board.
    • Make sure when unplugging the battery to not pull the manilla colored part which is attached to the board, but the white plug instead.
    • If you are working on the RIGHT side ear, you will first have to remove the charging contacts (2 7.92 mm Phillips screws).
  4. Turtle Beach Elite 800 Audio Board Replacement: Schritt 4, Bild 1 von 3 Turtle Beach Elite 800 Audio Board Replacement: Schritt 4, Bild 2 von 3 Turtle Beach Elite 800 Audio Board Replacement: Schritt 4, Bild 3 von 3
    • Desolder the necessary wires. (Each side will be slightly different.)
    • Be careful when using a soldering iron. Refer to the desoldering guide for tips.
    • For the purpose of this guide we clipped the wires connected to the board.
    • Remove the 4 screws (7.71mm Phillips head) using the #0 screw bit, that are holding the board in place.
    • Finally, remove the audio board.
Abschluss
2 weitere Personen haben diese Anleitung absolviert.
Johnny Lofton
861 Reputation
5 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 4
Letzte 30 Tage: 14
Insgesamt: 1,945
