Zum Hauptinhalt wechseln
Uniden UTAB71 Battery Replacement
Was du brauchst
  1. Uniden UTAB71 Battery Replacement, Battery: Schritt 1, Bild 1 von 2 Uniden UTAB71 Battery Replacement, Battery: Schritt 1, Bild 2 von 2
    • Use a plastic opening tool to undo the clips that attach the two halves of the tablet.
    • Be gentle with the pry tool and work your way around the edges of the tablet slowly.
    • Make sure the tablet is powered off before prying open.
    • There are two power ribbons connecting the screen to the back of the tablet. Make sure not to put too much stress on them.
  2. Uniden UTAB71 Battery Replacement: Schritt 2, Bild 1 von 1
    • Lift off the tape that holds the speaker wires to the battery
    • Leave the tape off to the side
  3. Uniden UTAB71 Battery Replacement: Schritt 3, Bild 1 von 1
    • Use a soldering tool to disconnect the two wires (red and black) that connect the battery to the motherboard
    • Note the placement of each colored wire in the motherboard
    • If you have no experience in soldering, please follow this guide
  4. Uniden UTAB71 Battery Replacement: Schritt 4, Bild 1 von 2 Uniden UTAB71 Battery Replacement: Schritt 4, Bild 2 von 2
    In diesem Schritt verwendetes Werkzeug:
    iOpener
    $12.99
    Kaufen
    • Use a credit card to lift the battery off the back of the tablet
    • Do not put any pressure on the motherboard or any other internal components.
    • The battery attached to the back panel with adhesive. You may need to use a heated iOpener to loosen the adhesive and remove the battery.
Abschluss
Ryan Jewell
422 Reputation
4 Anleitungen geschrieben
UMass Dartmouth, Team 5-4, Martin Fall 2016 Mitglied von UMass Dartmouth, Team 5-4, Martin Fall 2016
UMASSD-MARTIN-F16S5G4
3 Mitglieder
8 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 4
Letzte 30 Tage: 6
Insgesamt: 343
