Zum Hauptinhalt wechseln
Uniden UTAB71 Speaker Replacement
Was du brauchst
  1. Uniden UTAB71 Speaker Replacement, Speaker: Schritt 1, Bild 1 von 2 Uniden UTAB71 Speaker Replacement, Speaker: Schritt 1, Bild 2 von 2
    • Use a plastic pry tool to undo the clips that attach the two halves of the tablet.
    • Make sure to be gentle with the pry tool and work your way around the edges of the tablet slowly.
    • Make sure the tablet is powered off before prying open.
    • There are two power ribbons connecting the screen to the back of the tablet. Make sure not to put too much stress on them.
  2. Uniden UTAB71 Speaker Replacement: Schritt 2, Bild 1 von 1
    • Use a soldering tool to disconnect the speaker wires off the motherboard.
    • If you have no experience in soldering, please follow this guide
Abschluss
Ryan Jewell
422 Reputation
4 Anleitungen geschrieben
UMass Dartmouth, Team 5-4, Martin Fall 2016 Mitglied von UMass Dartmouth, Team 5-4, Martin Fall 2016
UMASSD-MARTIN-F16S5G4
3 Mitglieder
8 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 4
Letzte 30 Tage: 5
Insgesamt: 158
