Einleitung
Do any of the lights on your device appear to be dimly lit or not come on at all? Replacing the LEDs may solve your problem.
Was du brauchst
To remove the battery door, loosen the screw shown using a Phillips #2 screwdriver.
Using a Phillips #0 screwdriver, unscrew the six 7.3mm screws holding the screen together.
With the lid closed, position the device such that the handle is pointing towards you.
Using your fingers, gently pry open the cover from the hinge.
Pickup the array by the opening in the center of the board.
Remove the faulty LEDs by desoldering each from the board. You may refer to this soldering guide if necessary.
