Zum Hauptinhalt wechseln
VTech CS6719-2 Charging Wire Repair
Was du brauchst
  1. VTech CS6719-2 Charging Wire Repair, Base: Schritt 1, Bild 1 von 2 VTech CS6719-2 Charging Wire Repair, Base: Schritt 1, Bild 2 von 2
    • Remove the four Phillips #0 screws (9.4mm) located at the bottom of the phone on the back side of the base.
  2. VTech CS6719-2 Charging Wire Repair: Schritt 2, Bild 1 von 1
    • Use the spudger to separate the bottom from the top.
    • There are two clips, located top and bottom, that you have to compress with the spudger.
  3. VTech CS6719-2 Charging Wire Repair, Charging Wire: Schritt 3, Bild 1 von 1
    • Heat up solder joint on the circuit board where the charging wires are connected. Note: This is the CRD- and CRD+ terminals.
  4. VTech CS6719-2 Charging Wire Repair: Schritt 4, Bild 1 von 1
  5. VTech CS6719-2 Charging Wire Repair: Schritt 5, Bild 1 von 1
    • Heat up solder joint on the base unit where the charging wires are connected.
  6. VTech CS6719-2 Charging Wire Repair: Schritt 6, Bild 1 von 1
    • Take a wire of solder and apply to joint on board to remove the extra solder.
    • Note: Ensure the old solder joint is removed.
    • Caution: Soldering iron and joint will become very hot.
    • Remove charging wire connection.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
IUPUI, Team 1-4, Baechle Spring 2016 Mitglied von IUPUI, Team 1-4, Baechle Spring 2016
IUPUI-BAECHLE-S16S1G4
4 Mitglieder
16 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 5
Letzte 30 Tage: 10
Insgesamt: 1,371
