Einleitung
During this guide, the base will need to be disassembled and then desolder the charging wire connections.
Was du brauchst
Remove the four Phillips #0 screws (9.4mm) located at the bottom of the phone on the back side of the base.
Heat up solder joint on the circuit board where the charging wires are connected. Note: This is the CRD- and CRD+ terminals.
Refer to How to Solder and Desolder connections Wie man Lötverbindungen herstellt und entlötet
Take a wire of solder and apply to joint on board to remove the extra solder.
Note: Ensure the old solder joint is removed.
Caution: Soldering iron and joint will become very hot.
Remove charging wire connection.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
