Zum Hauptinhalt wechseln
VTech CS6719-2 Speaker Replacement
Was du brauchst
  1. VTech CS6719-2 Speaker Replacement, Battery: Schritt 1, Bild 1 von 2 VTech CS6719-2 Speaker Replacement, Battery: Schritt 1, Bild 2 von 2
    • Push down on the battery cover in the direction of the arrow located on the back of the phone.
  2. VTech CS6719-2 Speaker Replacement: Schritt 2, Bild 1 von 1
    • Pull the battery cover off of the back of the phone.
  3. VTech CS6719-2 Speaker Replacement: Schritt 3, Bild 1 von 1
    • Unplug the battery input cable.
  4. VTech CS6719-2 Speaker Replacement: Schritt 4, Bild 1 von 1
    • Lift the battery out of the back of the phone.
  5. VTech CS6719-2 Speaker Replacement, Circuit Board: Schritt 5, Bild 1 von 2 VTech CS6719-2 Speaker Replacement, Circuit Board: Schritt 5, Bild 2 von 2
    • Remove the two 9mm screws on the back side with a Phillips #0 screwdriver.
  6. VTech CS6719-2 Speaker Replacement: Schritt 6, Bild 1 von 1
    • Use the plastic opening tool and spudger to pry the back side of the phone off.
  7. VTech CS6719-2 Speaker Replacement: Schritt 7, Bild 1 von 2 VTech CS6719-2 Speaker Replacement: Schritt 7, Bild 2 von 2
    • Remove the two 9mm screws located inside the back cover at the top.
  8. VTech CS6719-2 Speaker Replacement, Speaker: Schritt 8, Bild 1 von 1
    In diesem Schritt verwendetes Werkzeug:
    Kaufen
    • Locate the metal shaped U clip holding the speaker on. Pull up and towards the top of the phone with the flat head tweezers.
    • The clip is loose, it could fall out.
  9. VTech CS6719-2 Speaker Replacement: Schritt 9, Bild 1 von 1
    • Lift speaker out.
  10. VTech CS6719-2 Speaker Replacement: Schritt 10, Bild 1 von 1
    • Heat up solder joint on the circuit board where the speaker wires are connected.
  11. VTech CS6719-2 Speaker Replacement: Schritt 11, Bild 1 von 1
Abschluss
Benjamin Field
270 Reputation
2 Anleitungen geschrieben
IUPUI, Team 1-4, Baechle Spring 2016 Mitglied von IUPUI, Team 1-4, Baechle Spring 2016
IUPUI-BAECHLE-S16S1G4
4 Mitglieder
16 Anleitungen geschrieben
2 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 8
Insgesamt: 740
