Zum Hauptinhalt wechseln
VTech InnoTab 2s Power Connector Replacement
Was du brauchst
  1. VTech InnoTab 2s Power Connector Replacement, Back Panel: Schritt 1, Bild 1 von 1
    • Turn your device to where the back panel is facing you.
  2. VTech InnoTab 2s Power Connector Replacement: Schritt 2, Bild 1 von 2 VTech InnoTab 2s Power Connector Replacement: Schritt 2, Bild 2 von 2
    • Lift the Leg all the way up and twist the bottom to remove.
    • Once the bottom part pops out the whole leg should just come off.
    • Remove any game cartridge from the device.
  3. VTech InnoTab 2s Power Connector Replacement: Schritt 3, Bild 1 von 3 VTech InnoTab 2s Power Connector Replacement: Schritt 3, Bild 2 von 3 VTech InnoTab 2s Power Connector Replacement: Schritt 3, Bild 3 von 3
    • Remove all of the plastic tabs on the device. These are covering screws that will need to be removed.
    • These covers are made of hard plastic so they may be difficult to remove.
    • There is a special tab in the cartridge cover that is made of rubber, make sure to not break this tab.
  4. VTech InnoTab 2s Power Connector Replacement: Schritt 4, Bild 1 von 2 VTech InnoTab 2s Power Connector Replacement: Schritt 4, Bild 2 von 2
    • Remove all nine screws from the back of the device using a J0 bit.
    • Remove the small battery.
  5. VTech InnoTab 2s Power Connector Replacement: Schritt 5, Bild 1 von 2 VTech InnoTab 2s Power Connector Replacement: Schritt 5, Bild 2 von 2
    • Using a plastic opening tool, detach the backplate from the front piece.
    • Do not use excessive force. Double check that you removed all the screws if the panel is not coming off easily.
    • Once the backplate has been removed, you will have access to the circuit board.
  6. VTech InnoTab 2s Power Connector Replacement, Motherboard: Schritt 6, Bild 1 von 1
    • First begin by removing the three cross-head screws using a J0 bit.
  7. VTech InnoTab 2s Power Connector Replacement: Schritt 7, Bild 1 von 1
    • First remove the ribbon cables. There are two highlighted by the red squares
    • Do not apply too much pressure and make sure that the black plastic tabs are fully open before you pull the cable out.
  8. VTech InnoTab 2s Power Connector Replacement: Schritt 8, Bild 1 von 1
    • Remove the camera from the assembly and put is a safe place so that it will not get damaged.
  9. VTech InnoTab 2s Power Connector Replacement: Schritt 9, Bild 1 von 1
    • Remove the board from the main assembly.
    • Be careful not to pull too hard so that the cables aren't broken.
  10. VTech InnoTab 2s Power Connector Replacement: Schritt 10, Bild 1 von 1
    • De-solder the points shown to fully remove the cables and free the board.
    • A soldering guide offered by IFIXIT can be found here Soldering Skills.
  11. VTech InnoTab 2s Power Connector Replacement, Power Connector: Schritt 11, Bild 1 von 1
    • Use a soldering tool to desolder the two highlighted points.
    • A soldering guide offered by IFIXIT can be found here: Soldering Skills.
  12. VTech InnoTab 2s Power Connector Replacement: Schritt 12, Bild 1 von 1
    • Use a screwdriver to remove the screw that is holding the power jack in place.
    • Now you have access to remove and replace the power jack.
Abschluss
USF Tampa, Team 5-1, Lacy Fall 2016 Mitglied von USF Tampa, Team 5-1, Lacy Fall 2016
USFT-LACY-F16S5G1
4 Mitglieder
12 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 2
Insgesamt: 352
