Zum Hauptinhalt wechseln
VTech Learning Tunes Karaoke Speaker Replacement
Was du brauchst
  1. VTech Learning Tunes Karaoke Speaker  Replacement, Speaker: Schritt 1, Bild 1 von 1
    • To remove the battery door, loosen the screw using a Flathead screwdriver.
    • A coin can also be used to loosen the screw.
  2. VTech Learning Tunes Karaoke Speaker  Replacement: Schritt 2, Bild 1 von 2 VTech Learning Tunes Karaoke Speaker  Replacement: Schritt 2, Bild 2 von 2
    • Remove the battery door and take out the batteries.
  3. VTech Learning Tunes Karaoke Speaker  Replacement: Schritt 3, Bild 1 von 1
    • Remove the six 9.5 mm Phillips #2 screws.
    • Remove the six 6.0 mm Phillips #2 screws.
  4. VTech Learning Tunes Karaoke Speaker  Replacement: Schritt 4, Bild 1 von 2 VTech Learning Tunes Karaoke Speaker  Replacement: Schritt 4, Bild 2 von 2
    • Gently pull up on the rear panel.
    • Be careful to not pull on the wire connections.
    • Carefully place the back panel underneath the top panel with the tops facing each other, as shown in the picture.
  5. VTech Learning Tunes Karaoke Speaker  Replacement: Schritt 5, Bild 1 von 2 VTech Learning Tunes Karaoke Speaker  Replacement: Schritt 5, Bild 2 von 2
    • Remove two 7.9 mm Phillips #1 screws on the speaker cover.
    • After removing the screws, remove the black plastic speaker cover to expose the speaker.
  6. VTech Learning Tunes Karaoke Speaker  Replacement: Schritt 6, Bild 1 von 1
    • Desolder the speaker at the solder points to remove.
    • Learn more about soldering and desoldering connections here.
Abschluss
USF Tampa, Team 7-2, Cheng Spring 2016 Mitglied von USF Tampa, Team 7-2, Cheng Spring 2016
USFT-CHENG-S16S7G2
4 Mitglieder
10 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 1
Letzte 30 Tage: 9
Insgesamt: 709
