Zum Hauptinhalt wechseln
VTech Safe and Sound DM111-2 Baby Unit Motherboard replacement Guide
Was du brauchst
  1. VTech Safe and Sound DM111-2  Baby Unit Motherboard replacement Guide, Baby Unit Motherboard replacement Guide: Schritt 1, Bild 1 von 1
    • Along the back of unit there are two 4mm philips head screws towards the bottom of the unit. Start by removing these two screws using your PH0 screwdriver.
  2. VTech Safe and Sound DM111-2  Baby Unit Motherboard replacement Guide: Schritt 2, Bild 1 von 2 VTech Safe and Sound DM111-2  Baby Unit Motherboard replacement Guide: Schritt 2, Bild 2 von 2
    • Using the plastic spudger gently pry along the middle of the 2 sections of the plastic housing in order to release plastic latches on the inside of the housing.
    • Unlike the parent unit there are no wires across the two housing pieces, so once the latches are undone simply pull it apart without worry of disconnecting anything.
  3. VTech Safe and Sound DM111-2  Baby Unit Motherboard replacement Guide: Schritt 3, Bild 1 von 2 VTech Safe and Sound DM111-2  Baby Unit Motherboard replacement Guide: Schritt 3, Bild 2 von 2
    • Once apart the motherboard will be exposed with two 4mm phillips head screws near the top and 4 wires leading leading to a circuit board hidden under the motherboard.
    • Remove the two screws near the top of the motherboard.
  4. VTech Safe and Sound DM111-2  Baby Unit Motherboard replacement Guide, Disconnect the microphone: Schritt 4, Bild 1 von 2 VTech Safe and Sound DM111-2  Baby Unit Motherboard replacement Guide, Disconnect the microphone: Schritt 4, Bild 2 von 2
    • Remove the strip of adhesive tape located under the motherboard.
    • Gently lift the motherboard to expose the inner components.
    • Use a spudger to scrape away the adhesive and foam connecting the microphone.
    • Unscrew the 4mm phillips head screw holding the microphone in place.
  5. VTech Safe and Sound DM111-2  Baby Unit Motherboard replacement Guide: Schritt 5, Bild 1 von 3 VTech Safe and Sound DM111-2  Baby Unit Motherboard replacement Guide: Schritt 5, Bild 2 von 3 VTech Safe and Sound DM111-2  Baby Unit Motherboard replacement Guide: Schritt 5, Bild 3 von 3
    In diesem Schritt verwendetes Werkzeug:
    Desoldering Pump
    $3.99
    Kaufen
    • Before de-soldering, check to see no scorching or broken connections appear on the wires, power supply jack or antenna.
    • De-solder the connections from the motherboard using a soldering iron and a solder sucker.
    • De-solder the connections to the microphone, located on the bottom left of the mother board.
    • De-solder the 4 wires connecting the LED board to the motherboard.
    • De-solder the antenna's solder joint, located above the microphone wire connection.
Abschluss
Jean Carlos
201 Reputation
2 Anleitungen geschrieben
USF Tampa, Team 6-3, Remmell Fall 2015 Mitglied von USF Tampa, Team 6-3, Remmell Fall 2015
USFT-REMMELL-F15S6G3
4 Mitglieder
7 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 4
Letzte 30 Tage: 5
Insgesamt: 904
