Zum Hauptinhalt wechseln
VTech Safe and Sound DM111-2 Speaker Replacement
Was du brauchst
  1. VTech Safe and Sound DM111-2 Speaker Replacement, Battery: Schritt 1, Bild 1 von 1
    • Expose the battery compartment by removing the lower back cover of the device.
    • Do this by holding the back side of the device upside down in your hands and applying pressure to the indented portion with both thumbs.
  2. VTech Safe and Sound DM111-2 Speaker Replacement: Schritt 2, Bild 1 von 1
    • Once the batteries are exposed, use your index finger to push the battery against the spring and pull up to dislodge the battery.
    • Make sure to check for battery acid or other corrosive substances before touching the battery. If needed, use latex gloves to avoid skin irritation from battery acid.
  3. VTech Safe and Sound DM111-2 Speaker Replacement, Speaker: Schritt 3, Bild 1 von 1
    • Use the Philips #0 Screwdriver to remove the two 11.2 mm screws located on either side of the battery slots.
  4. VTech Safe and Sound DM111-2 Speaker Replacement: Schritt 4, Bild 1 von 3 VTech Safe and Sound DM111-2 Speaker Replacement: Schritt 4, Bild 2 von 3 VTech Safe and Sound DM111-2 Speaker Replacement: Schritt 4, Bild 3 von 3
    • Use a plastic opening tool to gently disconnect the clips holding the case together.
    • Be careful when taking the case apart there are wires attached to the back case and the motherboard which should not be disconnected.
  5. VTech Safe and Sound DM111-2 Speaker Replacement: Schritt 5, Bild 1 von 2 VTech Safe and Sound DM111-2 Speaker Replacement: Schritt 5, Bild 2 von 2
    • Carefully unscrew the two 6.8 mm Philips head screws near the top of the device using the Philips#0 screw driver.
    • Be careful removing the motherboard because there will be a set of wires connecting the speaker and motherboard.
  6. VTech Safe and Sound DM111-2 Speaker Replacement: Schritt 6, Bild 1 von 1
    • Use a Philips#0 screwdriver and unscrew the two 6.8mm Philips screws holding the speaker in place.
  7. VTech Safe and Sound DM111-2 Speaker Replacement: Schritt 7, Bild 1 von 1
    • Remove the solder from the bottom left corner of the motherboard to completely detach the speaker from the device.
Abschluss
USF Tampa, Team 6-3, Remmell Fall 2015 Mitglied von USF Tampa, Team 6-3, Remmell Fall 2015
USFT-REMMELL-F15S6G3
4 Mitglieder
7 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 4
Letzte 7 Tage: 11
Letzte 30 Tage: 43
Insgesamt: 3,172
