Zum Hauptinhalt wechseln
Verizon Ellipsis 7 Power Button Replacement
Was du brauchst
  1. Verizon Ellipsis 7 Power Button Replacement, Power Button: Schritt 1, Bild 1 von 3 Verizon Ellipsis 7 Power Button Replacement, Power Button: Schritt 1, Bild 2 von 3 Verizon Ellipsis 7 Power Button Replacement, Power Button: Schritt 1, Bild 3 von 3
    • Power down device by holding down the power button until the screen goes black.
    • Remove the SIM card from the device to prevent damage.
    • To remove the SIM card, open the SIM card cover on the side of the device.
    • Push SIM card in, then remove after it pops out with an audible click.
  2. Verizon Ellipsis 7 Power Button Replacement: Schritt 2, Bild 1 von 2 Verizon Ellipsis 7 Power Button Replacement: Schritt 2, Bild 2 von 2
    • Take off the back panel.
    • Pry open the back cover carefully with a plastic opening tool.
    • Use the opening tool to disconnect the cover completely. Do not attempt to pull the back cover off with your hands.
    • Be sure to pry open all sides of the device. Attempting to take off the back cover when part of it is attached may snap the cover.
  3. Verizon Ellipsis 7 Power Button Replacement: Schritt 3, Bild 1 von 3 Verizon Ellipsis 7 Power Button Replacement: Schritt 3, Bild 2 von 3 Verizon Ellipsis 7 Power Button Replacement: Schritt 3, Bild 3 von 3
    • Remove the charging (micro-USB) port by unscrewing the indicated screws using the Phillips #00 screwdriver.
    • Disconnect the ribbon cable connecting the charging port board to the motherboard using tweezers.
    • Use the tweezers to grab the sides of black, plastic connector. Do not grab from the wires or try to wedge it out from the bottom.
    • Be extremely careful when disconnecting the ribbon cable. It is very delicate.
  4. Verizon Ellipsis 7 Power Button Replacement: Schritt 4, Bild 1 von 2 Verizon Ellipsis 7 Power Button Replacement: Schritt 4, Bild 2 von 2
    • Disconnect speakers from motherboard.
    • Use the tweezers to carefully disconnect speakers from motherboard.
  5. Verizon Ellipsis 7 Power Button Replacement: Schritt 5, Bild 1 von 3 Verizon Ellipsis 7 Power Button Replacement: Schritt 5, Bild 2 von 3 Verizon Ellipsis 7 Power Button Replacement: Schritt 5, Bild 3 von 3
    • Disconnect the battery.
    • Use tweezers to carefully disengage connector.
  6. Verizon Ellipsis 7 Power Button Replacement: Schritt 6, Bild 1 von 3 Verizon Ellipsis 7 Power Button Replacement: Schritt 6, Bild 2 von 3 Verizon Ellipsis 7 Power Button Replacement: Schritt 6, Bild 3 von 3
    • Disconnect the digitizer ribbon cable.
    • Use a nylon spudger to lift back tab.
    • After the back tab has been lifted the cable can be removed with tweezers.
    • When using tweezers, be careful not to damage the ribbon cable.
  7. Verizon Ellipsis 7 Power Button Replacement: Schritt 7, Bild 1 von 3 Verizon Ellipsis 7 Power Button Replacement: Schritt 7, Bild 2 von 3 Verizon Ellipsis 7 Power Button Replacement: Schritt 7, Bild 3 von 3
    • Disconnect the ribbon cable.
    • Use a nylon spudger to lift tab.
    • After the tab is lifted, the cable can be removed.
  8. Verizon Ellipsis 7 Power Button Replacement: Schritt 8, Bild 1 von 3 Verizon Ellipsis 7 Power Button Replacement: Schritt 8, Bild 2 von 3 Verizon Ellipsis 7 Power Button Replacement: Schritt 8, Bild 3 von 3
    • Disconnect all antenna cables.
    • Use a nylon spudger to pop the antenna cable from the base.
  9. Verizon Ellipsis 7 Power Button Replacement: Schritt 9, Bild 1 von 2 Verizon Ellipsis 7 Power Button Replacement: Schritt 9, Bild 2 von 2
    • Remove 9 Phillips #00 screws. The length of 4.76 mm
    • There is 1 Phillips #00 screw that is 3.175mm in length. This screw also has a larger head then the rest of the screws.
    • Note: when reassembling the motherboard, screw the bigger headed screw in the original location.
  10. Verizon Ellipsis 7 Power Button Replacement: Schritt 10, Bild 1 von 2 Verizon Ellipsis 7 Power Button Replacement: Schritt 10, Bild 2 von 2
    • Remove the motherboard.
    • Locate power button.
  11. Verizon Ellipsis 7 Power Button Replacement: Schritt 11, Bild 1 von 2 Verizon Ellipsis 7 Power Button Replacement: Schritt 11, Bild 2 von 2
    • Desolder the power button from the motherboard.
    • Learn how to solder and desolder components here!
Abschluss
2 weitere Nutzer:innen haben diese Anleitung absolviert.
Sam Houston State, Team 12-7, Blackburne Fall 2016 Mitglied von Sam Houston State, Team 12-7, Blackburne Fall 2016
SHSU-BLACKBURNE-F16S12G7
3 Mitglieder
10 Anleitungen geschrieben
2 Kommentare
I dropped mine and the button is broke. It looks like I should be able to just pop it back, but it's not reaching the button in the tablet. Do I really have to order this just for it to turn on? I mean, I use a paper clip, but I use this for Uber and it's not safe when I'm driving, lol.
tklahn79 - Antwort
I have looked everywhere for replacement buttons. Any help you can give in finding the parts is appreciated.
Regina Cain - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 9
Letzte 30 Tage: 14
Insgesamt: 1,865
