Einleitung
Complete the following guide to replace a dead or failing battery in the Visual Land Prestige Elite 7Q.
Was du brauchst
At the bottom of the tablet, remove the two 3.6mm screws with a Phillips #000 screwdriver.
In diesem Schritt verwendetes Werkzeug:Plastic Cards$2.99
Use a plastic card to loosen the battery from the tablet. Note that it will be sticky underneath the battery.
Use a soldering iron to detach the battery wires from the motherboard.
Replace the battery.
Abschluss
