Zum Hauptinhalt wechseln
Vivitar Vivicam T027 Power Button Replacement
Was du brauchst
  1. Vivitar Vivicam T027 Power Button Replacement, Power Button: Schritt 1, Bild 1 von 2 Vivitar Vivicam T027 Power Button Replacement, Power Button: Schritt 1, Bild 2 von 2
    • Using a Phillips #00 screwdriver, remove four exposed 3mm screws.
    • You will find one screw on the top, one on the bottom, and one on each side of the camera.
    • Put the screws in a safe place so you can find them and put them back in later.
  2. Vivitar Vivicam T027 Power Button Replacement: Schritt 2, Bild 1 von 1
    • Remove the sticker on the top of the camera.
    • Use the Phillips #00 screwdriver to remove the screw that was underneath the sticker.
  3. Vivitar Vivicam T027 Power Button Replacement: Schritt 3, Bild 1 von 2 Vivitar Vivicam T027 Power Button Replacement: Schritt 3, Bild 2 von 2
    • Separate the front and the back of the camera completely to expose the motherboard.
  4. Vivitar Vivicam T027 Power Button Replacement: Schritt 4, Bild 1 von 1
    In diesem Schritt verwendetes Werkzeug:
    Kaufen
    • Locate the power button on the top of the camera.
    • Using tweezers, gently remove the black plastic cover from the power button.
  5. Vivitar Vivicam T027 Power Button Replacement: Schritt 5, Bild 1 von 2 Vivitar Vivicam T027 Power Button Replacement: Schritt 5, Bild 2 von 2
    • Using a soldering kit, de-solder the black and red wire from the silver power button.
    • Solder the new power button to the black and red wire.
    • To avoid burns, be careful of the heat from the soldering iron.
    • Reference the soldering guide for assistance!
Abschluss
Dana
110 Reputation
1 Anleitung geschrieben
Marist, Team 15-13, Laflen Spring 2015 Mitglied von Marist, Team 15-13, Laflen Spring 2015
MARS-LAFLEN-S15S15G13
4 Mitglieder
3 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 10
Insgesamt: 914
