Einleitung
If your Vizio SmartCast Crave 360 (model SP50-DP) is making a muffled, fuzzy, or crackling sound, follow this guide to replace the bass component. A bass woofer producers the lower frequencies of music and sounds. A weak or broken bass woofer will create an unpleasant buzzing and scratching noise.
Before beginning, remove the Crave 360 from its charging base and turn off the device.
Was du brauchst
Orient the speaker so that the bottom faces up.
Peel the rubber ring off of the bottom using the spudger.
Remove the eight 5 mm screws connecting the bottom panel to the gray power port using a Phillips #000 screwdriver.
Remove the four 10 mm screws with that connect the bass to the rest of the speaker using a Phillips #000 screwdriver.
Take the bass component out of the speaker.
Disconnect the wiring that runs into the bass component.
The bass is now removed.
4 weitere Nutzer:innen haben diese Anleitung absolviert.
