Was du brauchst
Orient the speaker so that the bottom faces up.
Peel the rubber ring off of the bottom using the spudger.
Remove the eight 5 mm screws connecting the bottom panel to the gray power port using a Phillips #000 screwdriver.
Fast fertig!
Abschluss
