Einleitung
A faulty speaker can often lead to distorted audio or even no audio at all. This guide is designed to show how to correctly replace the speaker for your drum set in order to restore sound and proper function.
Was du brauchst
Locate the battery panel that is centered between the three leg supports at the bottom of the drum set.
To remove the battery panel, loosen the 10 mm panel screw using a flathead 4.0 screwdriver.
Loosen and remove the two 10mm screws using a Phillips #00 screwdriver.
Using a soldering station, carefully desolder the connection points on the speaker.
Eine weitere Person hat diese Anleitung absolviert.
