Zum Hauptinhalt wechseln
Vtech Kidizoom Smart Watch DX Buttons Replacement
Was du brauchst
  1. Vtech Kidizoom Smart Watch DX Buttons Replacement, Master Switch: Schritt 1, Bild 1 von 1
    • Make sure the master switch is "OFF" before disassembly, to avoid an electric shock.
    • Flip the watch over with the back facing up.
  2. Vtech Kidizoom Smart Watch DX Buttons Replacement: Schritt 2, Bild 1 von 1
    • Remove the four 6.0 mm screws on the back plate with the Phillips #00 screwdriver.
  3. Vtech Kidizoom Smart Watch DX Buttons Replacement: Schritt 3, Bild 1 von 1
    • Gently pull the back plate from the watch casing.
  4. Vtech Kidizoom Smart Watch DX Buttons Replacement: Schritt 4, Bild 1 von 2 Vtech Kidizoom Smart Watch DX Buttons Replacement: Schritt 4, Bild 2 von 2
    • Lift the master switch from the circuit board.
  5. Vtech Kidizoom Smart Watch DX Buttons Replacement, Circuit Board: Schritt 5, Bild 1 von 2 Vtech Kidizoom Smart Watch DX Buttons Replacement, Circuit Board: Schritt 5, Bild 2 von 2
    • The speaker wires are fragile. They may break if excessive force is used to remove the circuit board.
    • Removal of the circuit board requires soldering.
    • Gently push on the display from the front, near the camera. The circuit board and display will pop out through the back.
  6. Vtech Kidizoom Smart Watch DX Buttons Replacement: Schritt 6, Bild 1 von 1
    • Lift the circuit board carefully from the casing, without breaking or detaching the speaker wires at the bottom of the circuit board.
  7. Vtech Kidizoom Smart Watch DX Buttons Replacement: Schritt 7, Bild 1 von 1
    • Note which wire is connected to which lead before continuing. There are no markers on the circuit board to indicate where each wire belongs.
    • De-solder the black speaker wire from the circuit board.
  8. Vtech Kidizoom Smart Watch DX Buttons Replacement: Schritt 8, Bild 1 von 1
    • De-solder the red speaker wire, as in the previous step.
  9. Vtech Kidizoom Smart Watch DX Buttons Replacement: Schritt 9, Bild 1 von 1
    • Wait for the solder to cool down and solidify, then remove the circuit board from the casing.
  10. Vtech Kidizoom Smart Watch DX Buttons Replacement, Buttons: Schritt 10, Bild 1 von 1
    In diesem Schritt verwendetes Werkzeug:
    Kaufen
    • Use the the tweezers to pull off the blue rubber cover behind the button.
    • The blue cover is adhesive, so you can stick it back onto the back of the buttons after replacement.
  11. Vtech Kidizoom Smart Watch DX Buttons Replacement: Schritt 11, Bild 1 von 1
    • Use tweezers to separate the backside tab from the front side of the button.
  12. Vtech Kidizoom Smart Watch DX Buttons Replacement: Schritt 12, Bild 1 von 1
    • Push the other half of the button out of the casing.
    • Repeat steps 11 and 12 for all buttons.
Abschluss
2 weitere Personen haben diese Anleitung absolviert.
USF Tampa, Team 10-6, Remmell Spring 2016 Mitglied von USF Tampa, Team 10-6, Remmell Spring 2016
USFT-REMMELL-S16S10G6
4 Mitglieder
12 Anleitungen geschrieben
Ein Kommentar
Where can you buy the replacement cover?
Katrina Nullatamby - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 5
Letzte 30 Tage: 21
Insgesamt: 5,629
