Einleitung
If the buttons are not working properly, this guide will help you replace them. Note: This guide requires soldering.
Was du brauchst
Remove the four 6.0 mm screws on the back plate with the Phillips #00 screwdriver.
Gently push on the display from the front, near the camera. The circuit board and display will pop out through the back.
Lift the circuit board carefully from the casing, without breaking or detaching the speaker wires at the bottom of the circuit board.
Wait for the solder to cool down and solidify, then remove the circuit board from the casing.
Use the the tweezers to pull off the blue rubber cover behind the button.
Push the other half of the button out of the casing.
Repeat steps 11 and 12 for all buttons.
2 weitere Personen haben diese Anleitung absolviert.
