Einleitung
USB port not working anymore? Screen scratched, cracked, or broken? Or is the watch failing to work altogether? This guide can help. Note: This guide requires soldering.
Was du brauchst
Remove the four 6.0 mm screws on the back plate with the Phillips #00 screwdriver.
Gently push on the display from the front, near the camera. The circuit board and display will pop out through the back.
Lift the circuit board carefully from the casing, without breaking or detaching the speaker wires at the bottom of the circuit board.
Wait for the solder to cool down and solidify, then remove the circuit board from the casing.
7 weitere Nutzer:innen haben diese Anleitung absolviert.
2 Kommentare
Where can I buy the circuit board ?? Please send me a link or just post it please. Thanks
Where can I buy replacement and how much should it cost?
