Zum Hauptinhalt wechseln
WRS315SDHW Control Board Replacement
Was du brauchst
  1. WRS315SDHW Control Board Replacement, Safety precautions: Schritt 1, Bild 1 von 1
    • Before you begin your repair, perform the following:
    • Turn off your main water supply
    • Unplug your device
  2. WRS315SDHW Control Board Replacement, Unfasten the dispenser panels: Schritt 2, Bild 1 von 2 WRS315SDHW Control Board Replacement, Unfasten the dispenser panels: Schritt 2, Bild 2 von 2
    • The dispenser panel screws are located under the dispenser as if you're looking up into the dispenser tube (where the ice cubes and water come out).
    • Use a 1/4 inch socket wrench to remove the two 15.6 mm-long screws securing the two dispenser panels.
  3. WRS315SDHW Control Board Replacement, Remove the dispenser panels: Schritt 3, Bild 1 von 3 WRS315SDHW Control Board Replacement, Remove the dispenser panels: Schritt 3, Bild 2 von 3 WRS315SDHW Control Board Replacement, Remove the dispenser panels: Schritt 3, Bild 3 von 3
    • Pull the dispenser panels straight down to separate them from the chassis.
    • Remove the dispenser panels.
  4. WRS315SDHW Control Board Replacement, Unfasten the control board: Schritt 4, Bild 1 von 1
    • Use a 1/4 inch socket wrench to remove the two 15.6 mm-long screws securing the control board.
  5. WRS315SDHW Control Board Replacement: Schritt 5, Bild 1 von 3 WRS315SDHW Control Board Replacement: Schritt 5, Bild 2 von 3 WRS315SDHW Control Board Replacement: Schritt 5, Bild 3 von 3
    • Tilt the bottom of the control board away from the chassis to release its clips.
    • Pull straight down to separate the control board enough to access its connectors.
  6. WRS315SDHW Control Board Replacement, Disconnect the control board: Schritt 6, Bild 1 von 3 WRS315SDHW Control Board Replacement, Disconnect the control board: Schritt 6, Bild 2 von 3 WRS315SDHW Control Board Replacement, Disconnect the control board: Schritt 6, Bild 3 von 3
    • Disconnect the large connector attached to the right edge of the control board.
  7. WRS315SDHW Control Board Replacement: Schritt 7, Bild 1 von 2 WRS315SDHW Control Board Replacement: Schritt 7, Bild 2 von 2
    • Disconnect the small connector attached to the left edge of the control board.
  8. WRS315SDHW Control Board Replacement, Remove the control board: Schritt 8, Bild 1 von 1
    • Remove the control board.
Abschluss
Repair didn’t go as planned? Ask our Answers community for help.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
nicO
15.927 Reputation
88 Anleitungen geschrieben
Global Fixers Mitglied von Global Fixers
Community
33 Mitglieder
550 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 2
Letzte 30 Tage: 6
Insgesamt: 142
