Zum Hauptinhalt wechseln
WRS315SDHW Defrost Thermistor Replacement
Was du brauchst
  1. WRS315SDHW Defrost Thermistor Replacement, Safety precautions: Schritt 1, Bild 1 von 1
    • Before you begin your repair, perform the following:
    • Turn off your main water supply
    • Unplug your device
  2. WRS315SDHW Defrost Thermistor Replacement, Open the doors: Schritt 2, Bild 1 von 3 WRS315SDHW Defrost Thermistor Replacement, Open the doors: Schritt 2, Bild 2 von 3 WRS315SDHW Defrost Thermistor Replacement, Open the doors: Schritt 2, Bild 3 von 3
    • Depending on your repair, open one or both doors.
  3. WRS315SDHW Defrost Thermistor Replacement, Remove the drawers: Schritt 3, Bild 1 von 2 WRS315SDHW Defrost Thermistor Replacement, Remove the drawers: Schritt 3, Bild 2 von 2
    • Remove the drawers and shelves from the freezer section.
  4. WRS315SDHW Defrost Thermistor Replacement: Schritt 4, Bild 1 von 2 WRS315SDHW Defrost Thermistor Replacement: Schritt 4, Bild 2 von 2
    • Remove the screw(s) securing the evaporator cover.
  5. WRS315SDHW Defrost Thermistor Replacement, Unclip the evaporator cover: Schritt 5, Bild 1 von 3 WRS315SDHW Defrost Thermistor Replacement, Unclip the evaporator cover: Schritt 5, Bild 2 von 3 WRS315SDHW Defrost Thermistor Replacement, Unclip the evaporator cover: Schritt 5, Bild 3 von 3
    • Lift the bottom of the evaporator cover up and over its lip in the chassis.
    • Pull the cover toward yourself to release its top clips.
  6. WRS315SDHW Defrost Thermistor Replacement, Remove the evaporator cover: Schritt 6, Bild 1 von 3 WRS315SDHW Defrost Thermistor Replacement, Remove the evaporator cover: Schritt 6, Bild 2 von 3 WRS315SDHW Defrost Thermistor Replacement, Remove the evaporator cover: Schritt 6, Bild 3 von 3
    • Continue pulling the evaporator cover towards yourself to unclip its metal prongs from the chassis.
    • Remove the evaporator cover.
  7. WRS315SDHW Defrost Thermistor Replacement, Unclip the thermistor: Schritt 7, Bild 1 von 3 WRS315SDHW Defrost Thermistor Replacement, Unclip the thermistor: Schritt 7, Bild 2 von 3 WRS315SDHW Defrost Thermistor Replacement, Unclip the thermistor: Schritt 7, Bild 3 von 3
    • Use a spudger to push the tip of the thermistor through its slot in the wire harness.
  8. WRS315SDHW Defrost Thermistor Replacement, Disconnect the thermistor: Schritt 8, Bild 1 von 2 WRS315SDHW Defrost Thermistor Replacement, Disconnect the thermistor: Schritt 8, Bild 2 von 2
    • Disconnect the thermistor from the wiring harness.
  9. WRS315SDHW Defrost Thermistor Replacement, Remove the thermistor: Schritt 9, Bild 1 von 1
    • Remove the thermistor.
Abschluss
Repair didn’t go as planned? Ask our Answers community for help.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
nicO
15.927 Reputation
88 Anleitungen geschrieben
Global Fixers Mitglied von Global Fixers
Community
33 Mitglieder
560 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 6
Insgesamt: 114
