Einleitung
Use this guide to replace the door light in your Whirlpool WRS315SDHW Refrigerator.
The door light illuminates the right side of the refrigerator. If the lighting in your refrigerator is dim or dark, then the door light might be broken.
Note: Some photos show the doors removed for clarity purposes. Removing them is not required and will not change the procedure.
Was du brauchst
Carefully insert a flathead screwdriver, or a similar tool, between the door light and the chassis.
Pry up to separate the door light enough so you can grip it with your fingers.
Tilt the door light toward the right edge of the refrigerator to completely release its plastic clips.
Pull the light down to expose its connectors.
Disconnect the two spade connectors attached to the door light.
Remove the door light.
Repair didn’t go as planned? Ask our Answers community for help.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
