Einleitung
Use this guide to replace the drain pan in your Whirlpool WRS315SDHW Refrigerator.
The drain pan collects water from the defrost drain that eventually gets evaporated by the condenser. If your refrigerator is leaking water onto the floor, your drain pan might be bent or broken.
Note: Some photos show the doors removed for clarity purposes. Removing them is not required and will not change the procedure.
Was du brauchst
Use a Phillips driver to remove the two 15.2 mm-long screws securing the front panel.
Pull the front panel straight off the chassis and remove it.
Use a 1/4 inch socket wrench to remove the 16.7 mm-long screw securing the wiring harness.
Pull the wiring harness out of its slot in the chassis to access its connectors.
Disconnect the two connectors attached to the door wiring harness.
Use a 1/4 inch socket wrench, or a flathead screwdriver, to remove the seven 16.2 mm-long screws securing the rear panel.
Use a 1/4 inch socket wrench to loosen the screw securing the water hose enough for the rear panel to freely move.
Pull the condenser fan straight off its peg to remove it.
Use a flathead screwdriver, or a similar tool, to pry up the metal clip from the back of the drain pan.
Pull the wiring harness straight out of the chassis until you can access the drain pan.
Peel the tape off the front metal clip attached to the drain pan.
Use your fingers to release the metal clip on the front of the drain pan.
Fold the metal clip so that it lays flat on the floor of the chassis.
Pull the drain pan toward the front of the chassis to release any remaining clips.
Remove the drain pan.
Repair didn’t go as planned? Ask our Answers community for help.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
