Einleitung
Use this guide to replace the water filter housing in your Whirlpool WRS315SDHW Refrigerator.
The water filter housing stores the water filter and connects it to the water inlet valve assembly.
Note: Some photos show the doors removed for clarity purposes. Removing them is not required and will not change the procedure.
Was du brauchst
Use a Phillips driver to remove the two 15.2 mm-long screws securing the front panel.
Pull the front panel straight off the chassis and remove it.
Use a 1/4 inch socket wrench to remove the two 18.9 mm-long screws securing the water filter housing.
Use a 1/4 inch socket wrench, or a flathead screwdriver, to remove the 15.6 mm-long screw securing the wire harness grounding wire.
Pull the housing out of the chassis enough to access its left-hand water connections.
Place a clean and dry rag under the water hoses.
Use needle nose pliers, or your fingers, to remove the blue clip on the bottom water hose.
Repeat for the red clip on the top water hose.
Compress the plastic ring near the end of the water hose.
While compressing the ring, pull the hose away from the ring to disconnect it.
Repeat for the other water hose.
Repair didn’t go as planned? Ask our Answers community for help.
Eine weitere Person hat diese Anleitung absolviert.
