Einleitung
Use this guide to remove or replace the impeller on a Wacker PST2 400 (2008) Submersible Pump.
Was du brauchst
Pull to remove the two cotter pins securing the hose's locking arms, one on either side.
Flip the two locking arms down to unlock the hose collar.
Lift the hose away from the collar on the pump body to remove it.
Use a 13 mm socket to remove the three nuts securing the strainer assembly to the main body.
Lift the main body up and off of the strainer assembly.
Grip one of the impeller blades with a pair of needle nose pliers.
With the impeller held in place, use an adjustable wrench to loosen the stirrer nut securing the impeller to the main body.
Remove the stirrer nut.
Remove the lock washer from the face of the impeller.
Remove the flat washer.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
