Zum Hauptinhalt wechseln
Welch Allyn Connex Vital Signs Monitor 6000 Stand Replacement
Was du brauchst
  1. Welch Allyn Connex Vital Signs Monitor 6000 Stand Replacement, Stand: Schritt 1, Bild 1 von 2 Welch Allyn Connex Vital Signs Monitor 6000 Stand Replacement, Stand: Schritt 1, Bild 2 von 2
    • Unplug the AC power connection cable.
  2. Welch Allyn Connex Vital Signs Monitor 6000 Stand Replacement: Schritt 2, Bild 1 von 3 Welch Allyn Connex Vital Signs Monitor 6000 Stand Replacement: Schritt 2, Bild 2 von 3 Welch Allyn Connex Vital Signs Monitor 6000 Stand Replacement: Schritt 2, Bild 3 von 3
    • Place your thumb and forefinger on the blood pressure (NIBP) hose connector. Squeeze the side tabs until the connector releases.
    • Always grasp the hose by the connector. Do not pull on the hose itself.
    • Pull the connector away from the connector port.
  3. Welch Allyn Connex Vital Signs Monitor 6000 Stand Replacement: Schritt 3, Bild 1 von 3 Welch Allyn Connex Vital Signs Monitor 6000 Stand Replacement: Schritt 3, Bild 2 von 3 Welch Allyn Connex Vital Signs Monitor 6000 Stand Replacement: Schritt 3, Bild 3 von 3
    • Place your thumb and forefinger on the Pulse oximetry (SpO2 or combined SpO2/SpHb) cable connector. Squeeze the side tabs until the connector releases.
    • Always grasp the cable by the connector. Do not pull on the cable itself.
  4. Welch Allyn Connex Vital Signs Monitor 6000 Stand Replacement: Schritt 4, Bild 1 von 2 Welch Allyn Connex Vital Signs Monitor 6000 Stand Replacement: Schritt 4, Bild 2 von 2
    • Grasp the temperature probe and pull it up to remove it from the monitor.
  5. Welch Allyn Connex Vital Signs Monitor 6000 Stand Replacement: Schritt 5, Bild 1 von 3 Welch Allyn Connex Vital Signs Monitor 6000 Stand Replacement: Schritt 5, Bild 2 von 3 Welch Allyn Connex Vital Signs Monitor 6000 Stand Replacement: Schritt 5, Bild 3 von 3
    • Remove the cover of the temperature module by pressing the tab and sliding the cover to the right.
  6. Welch Allyn Connex Vital Signs Monitor 6000 Stand Replacement: Schritt 6, Bild 1 von 3 Welch Allyn Connex Vital Signs Monitor 6000 Stand Replacement: Schritt 6, Bild 2 von 3 Welch Allyn Connex Vital Signs Monitor 6000 Stand Replacement: Schritt 6, Bild 3 von 3
    • Depress the spring tab on the temperature probe cable connector and withdraw it from the probe port.
  7. Welch Allyn Connex Vital Signs Monitor 6000 Stand Replacement: Schritt 7, Bild 1 von 1
    • Remove the flathead screw on the USB networking door.
    • Loosen the captive Phillips #2 screw securing the monitor to the stand.
  8. Welch Allyn Connex Vital Signs Monitor 6000 Stand Replacement: Schritt 8, Bild 1 von 1
    • Holding the monitor securely, open the USB networking door.
    • You may have to lift the monitor slightly to allow the door to swing out from the stand mount.
  9. Welch Allyn Connex Vital Signs Monitor 6000 Stand Replacement: Schritt 9, Bild 1 von 2 Welch Allyn Connex Vital Signs Monitor 6000 Stand Replacement: Schritt 9, Bild 2 von 2
    • Detach any accessory USB cables from USB ports on the monitor.
  10. Welch Allyn Connex Vital Signs Monitor 6000 Stand Replacement: Schritt 10, Bild 1 von 3 Welch Allyn Connex Vital Signs Monitor 6000 Stand Replacement: Schritt 10, Bild 2 von 3 Welch Allyn Connex Vital Signs Monitor 6000 Stand Replacement: Schritt 10, Bild 3 von 3
    • Slide the monitor off of the stand tray.
Abschluss
Sam Goldheart
465.970 Reputation
538 Anleitungen geschrieben
iFixit Mitglied von iFixit
Staff
136 Mitglieder
17.299 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 4
Letzte 30 Tage: 15
Insgesamt: 875
