Zum Hauptinhalt wechseln
Weller WLC100 Soldering Station NTW56058 TRIAC 16amp switch Replacement
Was du brauchst
  1. Weller WLC100 Soldering Station  NTW56058 TRIAC 16amp switch Replacement, NTW56058 TRIAC 16amp switch: Schritt 1, Bild 1 von 1
    • Remove the knob from the adjustment dial.
  2. Weller WLC100 Soldering Station  NTW56058 TRIAC 16amp switch Replacement: Schritt 2, Bild 1 von 1
    • Remove two 8.6 mm Phillips #1 screws from soldering station bottom.
  3. Weller WLC100 Soldering Station  NTW56058 TRIAC 16amp switch Replacement: Schritt 3, Bild 1 von 1
    • Remove the rubber feet to access the remaining screws.
  4. Weller WLC100 Soldering Station  NTW56058 TRIAC 16amp switch Replacement: Schritt 4, Bild 1 von 1
    • Remove the remaining two 8.6 mm Phillips #1 screws from soldering station bottom.
  5. Weller WLC100 Soldering Station  NTW56058 TRIAC 16amp switch Replacement: Schritt 5, Bild 1 von 1
    • Separate the bottom and top half of the soldering station.
  6. Weller WLC100 Soldering Station  NTW56058 TRIAC 16amp switch Replacement: Schritt 6, Bild 1 von 1
    • Remove the adjustable heat dial board.
  7. Weller WLC100 Soldering Station  NTW56058 TRIAC 16amp switch Replacement: Schritt 7, Bild 1 von 2 Weller WLC100 Soldering Station  NTW56058 TRIAC 16amp switch Replacement: Schritt 7, Bild 2 von 2
    • Orient the new TRIAC switch the same way as the old TRIAC switch is located.
  8. Weller WLC100 Soldering Station  NTW56058 TRIAC 16amp switch Replacement: Schritt 8, Bild 1 von 2 Weller WLC100 Soldering Station  NTW56058 TRIAC 16amp switch Replacement: Schritt 8, Bild 2 von 2
  9. Weller WLC100 Soldering Station  NTW56058 TRIAC 16amp switch Replacement: Schritt 9, Bild 1 von 1
    • Remove the TRIAC switch when all the solder is removed from the pins.
  10. Weller WLC100 Soldering Station  NTW56058 TRIAC 16amp switch Replacement: Schritt 10, Bild 1 von 1
    • Insert the new TRIAC switch into the three holes left when you removed the old TRIAC switch.
  11. Weller WLC100 Soldering Station  NTW56058 TRIAC 16amp switch Replacement: Schritt 11, Bild 1 von 1
    • Solder the new TRIAC switch onto board.
  12. Weller WLC100 Soldering Station  NTW56058 TRIAC 16amp switch Replacement: Schritt 12, Bild 1 von 1
    • Verify all three pins are soldered in and the solder is not touching the other pins.
  13. Weller WLC100 Soldering Station  NTW56058 TRIAC 16amp switch Replacement: Schritt 13, Bild 1 von 1
    • Re-install the board into the soldering station.
  14. Weller WLC100 Soldering Station  NTW56058 TRIAC 16amp switch Replacement: Schritt 14, Bild 1 von 1
    • Push the knob into the hole so that is it protruding out of the other side.
  15. Weller WLC100 Soldering Station  NTW56058 TRIAC 16amp switch Replacement: Schritt 15, Bild 1 von 1
    • Verify the knob is sticking out of the other side of soldering station.
  16. Weller WLC100 Soldering Station  NTW56058 TRIAC 16amp switch Replacement: Schritt 16, Bild 1 von 1
    • Replace the dial onto the knob.
  17. Weller WLC100 Soldering Station  NTW56058 TRIAC 16amp switch Replacement: Schritt 17, Bild 1 von 1
    • Replace the bottom and replace all four screws and rubber feet, reversing steps four though two.
Abschluss
2 weitere Nutzer:innen haben diese Anleitung absolviert.
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 7
Letzte 30 Tage: 34
Insgesamt: 1,346
