Zum Hauptinhalt wechseln
Whirlpool Refrigerator Auger Motor Replacement
Was du brauchst
  1. Whirlpool Refrigerator Auger Motor Replacement, Safety precautions: Schritt 1, Bild 1 von 1
    • Before you begin your repair, perform the following:
    • Turn off your main water supply
    • Unplug your device
  2. Whirlpool Refrigerator Auger Motor Replacement, Open the doors: Schritt 2, Bild 1 von 3 Whirlpool Refrigerator Auger Motor Replacement, Open the doors: Schritt 2, Bild 2 von 3 Whirlpool Refrigerator Auger Motor Replacement, Open the doors: Schritt 2, Bild 3 von 3
    • Depending on your repair, open one or both doors.
  3. Whirlpool Refrigerator Auger Motor Replacement, Remove the icemaker tray: Schritt 3, Bild 1 von 2 Whirlpool Refrigerator Auger Motor Replacement, Remove the icemaker tray: Schritt 3, Bild 2 von 2
    • Pull the icemaker tray completely out of its slot in the chassis.
  4. Whirlpool Refrigerator Auger Motor Replacement, Unfasten the icemaker assembly: Schritt 4, Bild 1 von 2 Whirlpool Refrigerator Auger Motor Replacement, Unfasten the icemaker assembly: Schritt 4, Bild 2 von 2
    • Remove the screw(s) securing the icemaker assembly.
    • The second photo shows the potential screw locations in a removed icemaker assembly.
  5. Whirlpool Refrigerator Auger Motor Replacement, Reposition the icemaker assembly: Schritt 5, Bild 1 von 3 Whirlpool Refrigerator Auger Motor Replacement, Reposition the icemaker assembly: Schritt 5, Bild 2 von 3 Whirlpool Refrigerator Auger Motor Replacement, Reposition the icemaker assembly: Schritt 5, Bild 3 von 3
    • Pull the icemaker assembly off its slot in the chassis.
    • Let the assembly hang to access its connectors.
  6. Whirlpool Refrigerator Auger Motor Replacement, Disconnect the icemaker assembly: Schritt 6, Bild 1 von 3 Whirlpool Refrigerator Auger Motor Replacement, Disconnect the icemaker assembly: Schritt 6, Bild 2 von 3 Whirlpool Refrigerator Auger Motor Replacement, Disconnect the icemaker assembly: Schritt 6, Bild 3 von 3
    • Disconnect any connectors attached to the icemaker assembly.
  7. Whirlpool Refrigerator Auger Motor Replacement, Remove the icemaker assembly: Schritt 7, Bild 1 von 1
    • Remove the icemaker assembly.
  8. Whirlpool Refrigerator Auger Motor Replacement, Unfasten the icemaker auger assembly: Schritt 8, Bild 1 von 1
    • Remove the screw(s) securing the icemaker auger assembly.
  9. Whirlpool Refrigerator Auger Motor Replacement, Reposition the icemaker auger assembly: Schritt 9, Bild 1 von 3 Whirlpool Refrigerator Auger Motor Replacement, Reposition the icemaker auger assembly: Schritt 9, Bild 2 von 3 Whirlpool Refrigerator Auger Motor Replacement, Reposition the icemaker auger assembly: Schritt 9, Bild 3 von 3
    • Pull the icemaker auger assembly off of its slot in the chassis.
  10. Whirlpool Refrigerator Auger Motor Replacement, Disconnect the icemaker auger assembly: Schritt 10, Bild 1 von 3 Whirlpool Refrigerator Auger Motor Replacement, Disconnect the icemaker auger assembly: Schritt 10, Bild 2 von 3 Whirlpool Refrigerator Auger Motor Replacement, Disconnect the icemaker auger assembly: Schritt 10, Bild 3 von 3
    • Disconnect any connectors attached to the icemaker auger assembly.
  11. Whirlpool Refrigerator Auger Motor Replacement, Remove the icemaker auger assembly: Schritt 11, Bild 1 von 1
    • Remove the icemaker auger assembly.
  12. Whirlpool Refrigerator Auger Motor Replacement, Remove the auger fin: Schritt 12, Bild 1 von 3 Whirlpool Refrigerator Auger Motor Replacement, Remove the auger fin: Schritt 12, Bild 2 von 3 Whirlpool Refrigerator Auger Motor Replacement, Remove the auger fin: Schritt 12, Bild 3 von 3
    • Twist the auger fin clockwise until it separates from the assembly.
    • Remove the auger fin.
  13. Whirlpool Refrigerator Auger Motor Replacement, Unfasten the grounding wire: Schritt 13, Bild 1 von 1
    • Remove the screw(s) securing the grounding wire.
  14. Whirlpool Refrigerator Auger Motor Replacement, Unfasten the auger motor: Schritt 14, Bild 1 von 1
    • Remove the screw(s) securing the auger motor.
  15. Whirlpool Refrigerator Auger Motor Replacement, Disconnect the auger motor: Schritt 15, Bild 1 von 2 Whirlpool Refrigerator Auger Motor Replacement, Disconnect the auger motor: Schritt 15, Bild 2 von 2
    • Use needle nose pliers, or your hands, to disconnect the grounding wire from the auger motor.
  16. Whirlpool Refrigerator Auger Motor Replacement: Schritt 16, Bild 1 von 3 Whirlpool Refrigerator Auger Motor Replacement: Schritt 16, Bild 2 von 3 Whirlpool Refrigerator Auger Motor Replacement: Schritt 16, Bild 3 von 3
    • Disconnect the connectors attached to the auger motor.
  17. Whirlpool Refrigerator Auger Motor Replacement, Only the auger motor remains: Schritt 17, Bild 1 von 1
    • You're now left with the auger motor.
  18. Whirlpool Refrigerator Auger Motor Replacement, Meter the auger motor: Schritt 18, Bild 1 von 1
    • If you own a multimeter, you can test your auger motor's resistance.
    • A range between 5-50 Ω is acceptable.
Abschluss
Repair didn’t go as planned? Ask our Answers community for help.
nicO
15.987 Reputation
89 Anleitungen geschrieben
0 Kommentare zur Anleitung
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 10
Letzte 30 Tage: 46
Insgesamt: 2,277
