Zum Hauptinhalt wechseln
Whirlpool Refrigerator Door Light Replacement
Was du brauchst
  1. Whirlpool Refrigerator Door Light Replacement, Open the doors: Schritt 1, Bild 1 von 3 Whirlpool Refrigerator Door Light Replacement, Open the doors: Schritt 1, Bild 2 von 3 Whirlpool Refrigerator Door Light Replacement, Open the doors: Schritt 1, Bild 3 von 3
    • Depending on your repair, open one or both doors.
  2. Whirlpool Refrigerator Door Light Replacement, Unclip the door light: Schritt 2, Bild 1 von 2 Whirlpool Refrigerator Door Light Replacement, Unclip the door light: Schritt 2, Bild 2 von 2
    • Be careful during this step, as it's easy to scratch the interior of the fridge or crack cold and brittle plastic.
    • Carefully insert a flathead screwdriver, or a similar tool, between the door light and the chassis.
    • Pry up to separate the door light enough so you can grip it with your fingers.
  3. Whirlpool Refrigerator Door Light Replacement: Schritt 3, Bild 1 von 3 Whirlpool Refrigerator Door Light Replacement: Schritt 3, Bild 2 von 3 Whirlpool Refrigerator Door Light Replacement: Schritt 3, Bild 3 von 3
    • Tilt the door light downward to completely release its plastic clips.
    • Pull the light down to expose its connectors.
  4. Whirlpool Refrigerator Door Light Replacement: Schritt 4, Bild 1 von 3 Whirlpool Refrigerator Door Light Replacement: Schritt 4, Bild 2 von 3 Whirlpool Refrigerator Door Light Replacement: Schritt 4, Bild 3 von 3
    • Disconnect any connectors attached to the door light.
    • Remove the door light.
Abschluss
Repair didn’t go as planned? Ask our Answers community for help.
nicO Gurney
12.185 Reputation
58 Anleitungen geschrieben
iFixit Mitglied von iFixit
Community
141 Mitglieder
17.757 Anleitungen geschrieben
Ein Kommentar
Hello Gents,
I have a Kitchen aid fridge Model # KRFF300ESS01 and one of the top Led light is flickering they come as a set module # W10897058, and connected by interconnecting wiring, (concealed in the panel) can any one please help me as to how I can change them out.....the other light is good and there is a screw which holds up the plastic panel housing the lights, can I get them out by removing the panel or do I get them out by taking them out one at a time and how do I get the wiring in like that .....cant post any pictures but will appreciate any feed back,
ashley demonte - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzten 24 Stunden: 20
Letzten 7 Tage: 123
Letzten 30 Tage: 515
Insgesamt: 7,145
