Zum Hauptinhalt wechseln
Whirlpool Refrigerator Door Sensor Replacement
Was du brauchst
  1. Whirlpool Refrigerator Door Sensor Replacement, Open the doors: Schritt 1, Bild 1 von 3 Whirlpool Refrigerator Door Sensor Replacement, Open the doors: Schritt 1, Bild 2 von 3 Whirlpool Refrigerator Door Sensor Replacement, Open the doors: Schritt 1, Bild 3 von 3
    • Depending on your repair, open one or both doors.
  2. Whirlpool Refrigerator Door Sensor Replacement, Unclip the door sensor: Schritt 2, Bild 1 von 3 Whirlpool Refrigerator Door Sensor Replacement, Unclip the door sensor: Schritt 2, Bild 2 von 3 Whirlpool Refrigerator Door Sensor Replacement, Unclip the door sensor: Schritt 2, Bild 3 von 3
    • Insert a flathead screwdriver, or a similar tool, between the door sensor and the chassis.
    • Pry up to separate the door sensor enough so you can grip it with your fingers.
  3. Whirlpool Refrigerator Door Sensor Replacement, Remove the door sensor: Schritt 3, Bild 1 von 2 Whirlpool Refrigerator Door Sensor Replacement, Remove the door sensor: Schritt 3, Bild 2 von 2
    • Pull the door sensor through the chassis enough to access its connectors.
    • Disconnect any connectors attached to the door sensor.
    • Remove the door sensor.
  4. Whirlpool Refrigerator Door Sensor Replacement, Meter the door sensor: Schritt 4, Bild 1 von 2 Whirlpool Refrigerator Door Sensor Replacement, Meter the door sensor: Schritt 4, Bild 2 von 2
    • If you own a multimeter, you can test your door sensor's resistance.
    • Set the multimeter to the resistance or continuity measurement mode.
    • With the button in its neutral position, the multimeter should read "OL."
    • With the button pressed, the multimeter should read around 0Ω.
Abschluss
Repair didn’t go as planned? Ask our Answers community for help.
nicO
15.987 Reputation
89 Anleitungen geschrieben
0 Kommentare zur Anleitung
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 7
Letzte 7 Tage: 23
Letzte 30 Tage: 109
Insgesamt: 4,296
