Zum Hauptinhalt wechseln
Whirlpool Refrigerator Evaporator Fan Replacement
Was du brauchst
  1. Whirlpool Refrigerator Evaporator Fan Replacement, Safety precautions: Schritt 1, Bild 1 von 1
    • Before you begin your repair, perform the following:
    • Turn off your main water supply
    • Unplug your device
  2. Whirlpool Refrigerator Evaporator Fan Replacement, Open the doors: Schritt 2, Bild 1 von 3 Whirlpool Refrigerator Evaporator Fan Replacement, Open the doors: Schritt 2, Bild 2 von 3 Whirlpool Refrigerator Evaporator Fan Replacement, Open the doors: Schritt 2, Bild 3 von 3
    • Depending on your repair, open one or both doors.
  3. Whirlpool Refrigerator Evaporator Fan Replacement, Remove the drawers: Schritt 3, Bild 1 von 2 Whirlpool Refrigerator Evaporator Fan Replacement, Remove the drawers: Schritt 3, Bild 2 von 2
    • Remove the drawers and shelves from the freezer section.
  4. Whirlpool Refrigerator Evaporator Fan Replacement: Schritt 4, Bild 1 von 2 Whirlpool Refrigerator Evaporator Fan Replacement: Schritt 4, Bild 2 von 2
    • Remove the screw(s) securing the evaporator cover.
  5. Whirlpool Refrigerator Evaporator Fan Replacement, Unclip the evaporator cover: Schritt 5, Bild 1 von 3 Whirlpool Refrigerator Evaporator Fan Replacement, Unclip the evaporator cover: Schritt 5, Bild 2 von 3 Whirlpool Refrigerator Evaporator Fan Replacement, Unclip the evaporator cover: Schritt 5, Bild 3 von 3
    • Lift the bottom of the evaporator cover up and over its lip in the chassis.
    • Pull the cover toward yourself to release its top clips.
  6. Whirlpool Refrigerator Evaporator Fan Replacement, Remove the evaporator cover: Schritt 6, Bild 1 von 3 Whirlpool Refrigerator Evaporator Fan Replacement, Remove the evaporator cover: Schritt 6, Bild 2 von 3 Whirlpool Refrigerator Evaporator Fan Replacement, Remove the evaporator cover: Schritt 6, Bild 3 von 3
    • Continue pulling the evaporator cover towards yourself to unclip its metal prongs from the chassis.
    • Remove the evaporator cover.
  7. Whirlpool Refrigerator Evaporator Fan Replacement, Disconnect the evaporator fan: Schritt 7, Bild 1 von 2 Whirlpool Refrigerator Evaporator Fan Replacement, Disconnect the evaporator fan: Schritt 7, Bild 2 von 2
    • Use needle nose pliers, or your fingers, to disconnect the grounding wire(s) attached to the evaporator fan.
  8. Whirlpool Refrigerator Evaporator Fan Replacement: Schritt 8, Bild 1 von 3 Whirlpool Refrigerator Evaporator Fan Replacement: Schritt 8, Bild 2 von 3 Whirlpool Refrigerator Evaporator Fan Replacement: Schritt 8, Bild 3 von 3
    • Disconnect any connectors attached to the evaporator fan.
  9. Whirlpool Refrigerator Evaporator Fan Replacement, Unfasten the evaporator fan: Schritt 9, Bild 1 von 1
    • Remove the screw(s) securing the evaporator fan.
  10. Whirlpool Refrigerator Evaporator Fan Replacement, Remove the foam buffers: Schritt 10, Bild 1 von 3 Whirlpool Refrigerator Evaporator Fan Replacement, Remove the foam buffers: Schritt 10, Bild 2 von 3 Whirlpool Refrigerator Evaporator Fan Replacement, Remove the foam buffers: Schritt 10, Bild 3 von 3
    • Slide the foam buffer downward to release it from its lip in the chassis.
    • Remove the foam buffer.
    • Repeat this procedure any remaining foam buffers.
  11. Whirlpool Refrigerator Evaporator Fan Replacement, Remove the evaporator fan housing: Schritt 11, Bild 1 von 3 Whirlpool Refrigerator Evaporator Fan Replacement, Remove the evaporator fan housing: Schritt 11, Bild 2 von 3 Whirlpool Refrigerator Evaporator Fan Replacement, Remove the evaporator fan housing: Schritt 11, Bild 3 von 3
    • Pull the evaporator fan housing up and outward from the chassis to remove it.
  12. Whirlpool Refrigerator Evaporator Fan Replacement, Remove the fan: Schritt 12, Bild 1 von 2 Whirlpool Refrigerator Evaporator Fan Replacement, Remove the fan: Schritt 12, Bild 2 von 2
    • Pull the evaporator fan straight off its motor to remove it.
    • This may require some significant force.
  13. Whirlpool Refrigerator Evaporator Fan Replacement, Remove the motor bracket: Schritt 13, Bild 1 von 3 Whirlpool Refrigerator Evaporator Fan Replacement, Remove the motor bracket: Schritt 13, Bild 2 von 3 Whirlpool Refrigerator Evaporator Fan Replacement, Remove the motor bracket: Schritt 13, Bild 3 von 3
    • Use your fingers to pry up and release the motor bracket clips from the housing.
  14. Whirlpool Refrigerator Evaporator Fan Replacement, Remove the motor bracket: Schritt 14, Bild 1 von 2 Whirlpool Refrigerator Evaporator Fan Replacement, Remove the motor bracket: Schritt 14, Bild 2 von 2
    • Remove the motor bracket.
  15. Whirlpool Refrigerator Evaporator Fan Replacement, Remove the motor: Schritt 15, Bild 1 von 3 Whirlpool Refrigerator Evaporator Fan Replacement, Remove the motor: Schritt 15, Bild 2 von 3 Whirlpool Refrigerator Evaporator Fan Replacement, Remove the motor: Schritt 15, Bild 3 von 3
    • Pull the motor straight out of its housing to remove it.
Abschluss
Repair didn’t go as planned? Ask our Answers community for help.
nicO
15.885 Reputation
88 Anleitungen geschrieben
Global Fixers Mitglied von Global Fixers
Community
33 Mitglieder
549 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 8
Letzte 7 Tage: 63
Letzte 30 Tage: 301
Insgesamt: 3,517
