Zum Hauptinhalt wechseln
Whirlpool Refrigerator Icemaker Assembly Replacement
Was du brauchst
  1. Whirlpool Refrigerator Icemaker Assembly Replacement, Safety precautions: Schritt 1, Bild 1 von 1
    • Before you begin your repair, perform the following:
    • Turn off your main water supply
    • Unplug your device
  2. Whirlpool Refrigerator Icemaker Assembly Replacement, Open the doors: Schritt 2, Bild 1 von 3 Whirlpool Refrigerator Icemaker Assembly Replacement, Open the doors: Schritt 2, Bild 2 von 3 Whirlpool Refrigerator Icemaker Assembly Replacement, Open the doors: Schritt 2, Bild 3 von 3
    • Depending on your repair, open one or both doors.
  3. Whirlpool Refrigerator Icemaker Assembly Replacement, Remove the icemaker tray: Schritt 3, Bild 1 von 2 Whirlpool Refrigerator Icemaker Assembly Replacement, Remove the icemaker tray: Schritt 3, Bild 2 von 2
    • Pull the icemaker tray completely out of its slot in the chassis.
  4. Whirlpool Refrigerator Icemaker Assembly Replacement, Unfasten the icemaker assembly: Schritt 4, Bild 1 von 2 Whirlpool Refrigerator Icemaker Assembly Replacement, Unfasten the icemaker assembly: Schritt 4, Bild 2 von 2
    • Remove the screw(s) securing the icemaker assembly.
    • The second photo shows the potential screw locations in a removed icemaker assembly.
  5. Whirlpool Refrigerator Icemaker Assembly Replacement, Reposition the icemaker assembly: Schritt 5, Bild 1 von 3 Whirlpool Refrigerator Icemaker Assembly Replacement, Reposition the icemaker assembly: Schritt 5, Bild 2 von 3 Whirlpool Refrigerator Icemaker Assembly Replacement, Reposition the icemaker assembly: Schritt 5, Bild 3 von 3
    • Pull the icemaker assembly off its slot in the chassis.
    • Let the assembly hang to access its connectors.
  6. Whirlpool Refrigerator Icemaker Assembly Replacement, Disconnect the icemaker assembly: Schritt 6, Bild 1 von 3 Whirlpool Refrigerator Icemaker Assembly Replacement, Disconnect the icemaker assembly: Schritt 6, Bild 2 von 3 Whirlpool Refrigerator Icemaker Assembly Replacement, Disconnect the icemaker assembly: Schritt 6, Bild 3 von 3
    • Disconnect any connectors attached to the icemaker assembly.
  7. Whirlpool Refrigerator Icemaker Assembly Replacement, Remove the icemaker assembly: Schritt 7, Bild 1 von 1
    • Remove the icemaker assembly.
Abschluss
Repair didn’t go as planned? Ask our Answers community for help.
Eine weitere Person hat diese Anleitung absolviert.
nicO
15.987 Reputation
89 Anleitungen geschrieben
0 Kommentare zur Anleitung
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 7
Letzte 7 Tage: 50
Letzte 30 Tage: 217
Insgesamt: 8,242
