Zum Hauptinhalt wechseln
Whirlpool Refrigerator Temperature Control Board Replacement
Was du brauchst
  1. Whirlpool Refrigerator Temperature Control Board Replacement, Safety precautions: Schritt 1, Bild 1 von 1
    • Before you begin your repair, perform the following:
    • Turn off your main water supply
    • Unplug your device
    Frag FixBot
    Kommentar hinzufügen
  2. Whirlpool Refrigerator Temperature Control Board Replacement, Open the doors: Schritt 2, Bild 1 von 3 Whirlpool Refrigerator Temperature Control Board Replacement, Open the doors: Schritt 2, Bild 2 von 3 Whirlpool Refrigerator Temperature Control Board Replacement, Open the doors: Schritt 2, Bild 3 von 3
    • Depending on your repair, open one or both doors.
    Frag FixBot
  3. Whirlpool Refrigerator Temperature Control Board Replacement, Unfasten the temperature control board assembly: Schritt 3, Bild 1 von 2 Whirlpool Refrigerator Temperature Control Board Replacement, Unfasten the temperature control board assembly: Schritt 3, Bild 2 von 2
    • Remove the screw(s) securing the temperature control board assembly.
    • The second photo shows the potential screw locations in a removed assembly.
    Frag FixBot
  4. Whirlpool Refrigerator Temperature Control Board Replacement, Reposition the assembly: Schritt 4, Bild 1 von 3 Whirlpool Refrigerator Temperature Control Board Replacement, Reposition the assembly: Schritt 4, Bild 2 von 3 Whirlpool Refrigerator Temperature Control Board Replacement, Reposition the assembly: Schritt 4, Bild 3 von 3
    • Pull the temperature control board assembly off its slot in the chassis.
    • Let the assembly hang to access its connectors.
    Frag FixBot
  5. Whirlpool Refrigerator Temperature Control Board Replacement, Disconnect the temperature control board: Schritt 5, Bild 1 von 3 Whirlpool Refrigerator Temperature Control Board Replacement, Disconnect the temperature control board: Schritt 5, Bild 2 von 3 Whirlpool Refrigerator Temperature Control Board Replacement, Disconnect the temperature control board: Schritt 5, Bild 3 von 3
    • Disconnect any connectors attached to the temperature control board assembly.
    Frag FixBot
  6. Whirlpool Refrigerator Temperature Control Board Replacement, Remove the assembly: Schritt 6, Bild 1 von 1
    • Remove the temperature control board assembly.
    Frag FixBot
  7. Whirlpool Refrigerator Temperature Control Board Replacement, Separate the temperature control board: Schritt 7, Bild 1 von 3 Whirlpool Refrigerator Temperature Control Board Replacement, Separate the temperature control board: Schritt 7, Bild 2 von 3 Whirlpool Refrigerator Temperature Control Board Replacement, Separate the temperature control board: Schritt 7, Bild 3 von 3
    • Use a flathead screwdriver, or a similar tool, to compress the plastic clip securing the temperature control board.
    • Use another flathead screwdriver to pry up the board from its housing.
    Frag FixBot
  8. Whirlpool Refrigerator Temperature Control Board Replacement, Remove the temperature control board: Schritt 8, Bild 1 von 1
    • Pull the temperature control board straight out of its housing to remove it.
    Frag FixBot
Abschluss
Repair didn’t go as planned? Ask our Answers community for help.
nicO
15.990 Reputation
89 Anleitungen geschrieben
0 Kommentare zur Anleitung
Seitenaufrufe:
Letzte 24 Stunden: 8
Letzte 7 Tage: 24
Letzte 30 Tage: 89
Insgesamt: 2,392
