Zum Hauptinhalt wechseln
Whirlpool Refrigerator Water Inlet Valve Replacement
Was du brauchst
  1. Whirlpool Refrigerator Water Inlet Valve Replacement, Safety precautions: Schritt 1, Bild 1 von 1
    • Before you begin your repair, perform the following:
    • Turn off your main water supply
    • Unplug your device
    Frag FixBot
    Kommentar hinzufügen
  2. Whirlpool Refrigerator Water Inlet Valve Replacement, Unfasten the rear panel: Schritt 2, Bild 1 von 3 Whirlpool Refrigerator Water Inlet Valve Replacement, Unfasten the rear panel: Schritt 2, Bild 2 von 3 Whirlpool Refrigerator Water Inlet Valve Replacement, Unfasten the rear panel: Schritt 2, Bild 3 von 3
    • Remove the screw(s) securing the rear panel.
    • Loosen the screw securing the water hose enough for the rear panel to freely move.
    Frag FixBot
  3. Whirlpool Refrigerator Water Inlet Valve Replacement, Remove the rear panel: Schritt 3, Bild 1 von 3 Whirlpool Refrigerator Water Inlet Valve Replacement, Remove the rear panel: Schritt 3, Bild 2 von 3 Whirlpool Refrigerator Water Inlet Valve Replacement, Remove the rear panel: Schritt 3, Bild 3 von 3
    • Pull the rear panel off the chassis to remove it.
    Frag FixBot
  4. Whirlpool Refrigerator Water Inlet Valve Replacement, Remove the clip: Schritt 4, Bild 1 von 2 Whirlpool Refrigerator Water Inlet Valve Replacement, Remove the clip: Schritt 4, Bild 2 von 2
    • Use needle nose pliers, or your fingers, to remove the plastic clip on the inlet valve assembly.
    Frag FixBot
  5. Whirlpool Refrigerator Water Inlet Valve Replacement, Disconnect the front water hose: Schritt 5, Bild 1 von 3 Whirlpool Refrigerator Water Inlet Valve Replacement, Disconnect the front water hose: Schritt 5, Bild 2 von 3 Whirlpool Refrigerator Water Inlet Valve Replacement, Disconnect the front water hose: Schritt 5, Bild 3 von 3
    • Push the plastic ring above the front water hose to release its clips.
    • As you push the ring, pull the water hose downward to disconnect it.
    • Repeat the disconnection procedure for the other water hose on the inlet valve assembly.
    Frag FixBot
  6. Whirlpool Refrigerator Water Inlet Valve Replacement, Unfasten the inlet valve assembly: Schritt 6, Bild 1 von 1
    • Remove the screw(s) securing the inlet valve assembly.
    Frag FixBot
  7. Whirlpool Refrigerator Water Inlet Valve Replacement, Reposition the inlet valve assembly: Schritt 7, Bild 1 von 3 Whirlpool Refrigerator Water Inlet Valve Replacement, Reposition the inlet valve assembly: Schritt 7, Bild 2 von 3 Whirlpool Refrigerator Water Inlet Valve Replacement, Reposition the inlet valve assembly: Schritt 7, Bild 3 von 3
    • Pull the inlet valve assembly off its slot in the chassis and rest it on the floor.
    Frag FixBot
  8. Whirlpool Refrigerator Water Inlet Valve Replacement: Schritt 8, Bild 1 von 2 Whirlpool Refrigerator Water Inlet Valve Replacement: Schritt 8, Bild 2 von 2
    • Place a clean and dry rag under the inlet valve assembly before continuing.
    Frag FixBot
  9. Whirlpool Refrigerator Water Inlet Valve Replacement, Remove the clip: Schritt 9, Bild 1 von 2 Whirlpool Refrigerator Water Inlet Valve Replacement, Remove the clip: Schritt 9, Bild 2 von 2
    • Use needle nose pliers, or your hands, to pull the clip off the rear water hose.
    Frag FixBot
  10. Whirlpool Refrigerator Water Inlet Valve Replacement: Schritt 10, Bild 1 von 3 Whirlpool Refrigerator Water Inlet Valve Replacement: Schritt 10, Bild 2 von 3 Whirlpool Refrigerator Water Inlet Valve Replacement: Schritt 10, Bild 3 von 3
    • Push the yellow plastic ring above the rear water hose to release its clips.
    • As you push the ring, pull the water hose away from the inlet valve assembly to disconnect it.
    Frag FixBot
  11. Whirlpool Refrigerator Water Inlet Valve Replacement, Disconnect the assembly wire connector: Schritt 11, Bild 1 von 3 Whirlpool Refrigerator Water Inlet Valve Replacement, Disconnect the assembly wire connector: Schritt 11, Bild 2 von 3 Whirlpool Refrigerator Water Inlet Valve Replacement, Disconnect the assembly wire connector: Schritt 11, Bild 3 von 3
    • Use a flathead screwdriver, or a similar tool, to disconnect any wire connectors attached to the inlet valve assembly.
    Frag FixBot
  12. Whirlpool Refrigerator Water Inlet Valve Replacement, Remove the inlet valve assembly: Schritt 12, Bild 1 von 1
    • Remove the inlet valve assembly from the chassis.
    Frag FixBot
  13. Whirlpool Refrigerator Water Inlet Valve Replacement, Meter the inlet valve assembly: Schritt 13, Bild 1 von 1
    • If you own a multimeter, you can test your inlet valve assembly's resistance.
    • A range between 500–1.5 kΩ is acceptable.
    Frag FixBot
Abschluss
Repair didn’t go as planned? Ask our Answers community for help.
Eine weitere Person hat diese Anleitung absolviert.
nicO
15.990 Reputation
89 Anleitungen geschrieben
0 Kommentare zur Anleitung
Seitenaufrufe:
Letzte 24 Stunden: 17
Letzte 7 Tage: 99
Letzte 30 Tage: 491
Insgesamt: 14,617
