Einleitung
The remote control motherboard plays a major part in the connection between the remote control and the car. This guide steps you through replacing it.
Was du brauchst
Turn off the remote control. Flip power switch to the off position.
Remove the battery from bottom of the remote control for further safety measures.
Remove five 3mm Phillips #2 screws that connect the motherboard to the back outer shell.
Detach the motherboard. Use soldering tools to desolder the red and black wires from the motherboard. To do this, refer to the how to solder/desolder page.
