Einleitung
A lot of us have heard about the red ring of death, E74, and other hardware errors and a very common question is "how do I prevent this from happening?"
Well, it's quite simple actually. It is very important that the systems are well ventilated. This includes other hot electronics to be away from your system. You want nice cool air to be brought into the system and hot air being blown out and away from it. We recommend six inches ALL around the console.
If you have dust build up in the system, the hot air can't escape due to a barrier of dust being built up on the heat sinks inside. Blow the system out once a month with a can of pressurized air that you use to clean your keyboard or any kind of pressured air that is strong enough to break up the dust build up. Some have used a strong vaccuum to suck the dirt out which will work as long as the suction is strong enough.
These are the two main factors that cause the errors. If you've done all this and the system fails, it is truly a hardware failure that you could not prevent from happening. All electronics fail sooner or later, nothing last forever.
Werkzeuge
Ersatzteile
Keine Ersatzteile angegeben.
Very nice examples here of being well ventilated.
Don't have your system like this.
Avoid having other electronics such as your tv or dvd player close to the console.
Follow these guidelines and it'll help your system breathe that much better.
45 weitere Nutzer haben diese Anleitung absolviert.
5 Kommentare
This guide should have steps and cover a single topic. You should split this guide in two, one for how to store the Xbox in a well ventilated area (not just examples, but directions) and another for how to clean the heat sink. The best guides can be referenced in any context and are detailed instructions to reach a goal, as opposed to guidelines or examples of proper use. Good idea though, preventing issues is better than solving them!
Good points made by Alex.
Most obviously, where should you blow into the xbox to clear out the dust? A couple red circles around the best holes to stick the straw into to blow out the dust would be very helpful.
One should also take into consideration that dust and overheating are not truly the cause of a RRoD error unless it's simply overheating. I've reballed plenty on consoles, as new as 2009, with no dust whatsoever in the system. I've also done tray cleaning and lubrication on consoles that were filled with thick layers of dust without ever red ringing.
