Zum Hauptinhalt wechseln
Xbox One Stereo Headset Microphone Replacement
Was du brauchst
  1. Xbox One Stereo Headset Microphone Replacement, Microphone: Schritt 1, Bild 1 von 3 Xbox One Stereo Headset Microphone Replacement, Microphone: Schritt 1, Bild 2 von 3 Xbox One Stereo Headset Microphone Replacement, Microphone: Schritt 1, Bild 3 von 3
    • Use the flat end of a spudger to pry out the rubber stopper at the base of the boom.
  2. Xbox One Stereo Headset Microphone Replacement: Schritt 2, Bild 1 von 1
    • Remove the single 6 mm flathead #2.0 screw exposed after removing the rubber stopper.
  3. Xbox One Stereo Headset Microphone Replacement: Schritt 3, Bild 1 von 1
    • Lift the joint of the boom up and over its pivot point to separate the microphone from the headset.
  4. Xbox One Stereo Headset Microphone Replacement: Schritt 4, Bild 1 von 3 Xbox One Stereo Headset Microphone Replacement: Schritt 4, Bild 2 von 3 Xbox One Stereo Headset Microphone Replacement: Schritt 4, Bild 3 von 3
    • Using the flat end of the metal spudger, pry the back plate off the boom.
    • The back plate is glued to the boom and must be removed gently.
    • When re-installing, apply a few drops of super glue to hold it in place.
  5. Xbox One Stereo Headset Microphone Replacement: Schritt 5, Bild 1 von 1
    • Pull the back plate off the boom.
  6. Xbox One Stereo Headset Microphone Replacement: Schritt 6, Bild 1 von 1
    • Using the flat end of the plastic spudger, gently pry the microphone out of its casing.
    • Desolder the two wires from the back of the microphone. For instructions on how to solder and desolder, please see the soldering technique guide.
    • The white wire connects to the positive node, which is indicated with a "+" on the microphone.
Abschluss
4 weitere Nutzer:innen haben diese Anleitung absolviert.
Cal Poly, Team 17-37, Amido Winter 2015 Mitglied von Cal Poly, Team 17-37, Amido Winter 2015
CPSU-AMIDO-W15S17G37
4 Mitglieder
5 Anleitungen geschrieben
9 Kommentare
Is a replacement microphone available from iFixit?
Scott Minton - Antwort
What do you replace the mic with?
Its Me - Antwort
They have the microphone for sale
daniel david guerrerogarcia - Antwort
Would it presumably be just as easy to replace the microphone speaker with one from another headset, granted it fits ?
harumscxarum - Antwort
Any mod to make the cable removable?
kikis.andcream - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 3
Letzte 7 Tage: 16
Letzte 30 Tage: 40
Insgesamt: 23,853
