Zum Hauptinhalt wechseln
Xelio P900A-BK Battery Replacement
Was du brauchst
  1. Xelio P900A-BK Battery Replacement, Battery: Schritt 1, Bild 1 von 1
    • Using a #00 Phillips head screwdriver, remove the two 5.4mm bottom screws.
  2. Xelio P900A-BK Battery Replacement: Schritt 2, Bild 1 von 2 Xelio P900A-BK Battery Replacement: Schritt 2, Bild 2 von 2
    • Insert a plastic opening tool between the screen and the rear case and gently work your way around the tablet.
  3. Xelio P900A-BK Battery Replacement: Schritt 3, Bild 1 von 1
    • Using the plastic opening tool or your fingers, gently pry the pieces of the tablet apart. You will hear the plastic latches pop free.
  4. Xelio P900A-BK Battery Replacement: Schritt 4, Bild 1 von 3 Xelio P900A-BK Battery Replacement: Schritt 4, Bild 2 von 3 Xelio P900A-BK Battery Replacement: Schritt 4, Bild 3 von 3
  5. Xelio P900A-BK Battery Replacement: Schritt 5, Bild 1 von 2 Xelio P900A-BK Battery Replacement: Schritt 5, Bild 2 von 2
    • Carefully insert the flat end of a nylon spudger under the battery, and pry the battery up and away from the tablet casing.
    • A small amount of heat may be required to safely remove the battery from the adhesive underneath. Use an iOpener or heat gun to soften the adhesive.
    • Do not bend or puncture the battery.
    • Place the new battery in the same place as the old one, making sure it is oriented the same way as the old one was.
Abschluss
2 weitere Nutzer:innen haben diese Anleitung absolviert.
Marcus Nelson
307 Reputation
3 Anleitungen geschrieben
UMass Dartmouth, Team 7-6, Cichon Spring 2015 Mitglied von UMass Dartmouth, Team 7-6, Cichon Spring 2015
UMASSD-CICHON-S15S7G6
3 Mitglieder
8 Anleitungen geschrieben
Ein Kommentar
I am attempting to fix one of these for a friend, but I can't seem to get it open! Does it require a significant amount of force? I am afraid I will break it...
skatermonkey06 - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 5
Letzte 30 Tage: 7
Insgesamt: 340
