Einleitung
Your Xiaomi Redmi Note 8’s display can crack or break because of drops or unsuitable operation. Use this guide to replace a broken screen on a Xiaomi Redmi Note 8 Pro smartphone.
This guide involves removing the back cover of the device, so you will need a replacement adhesive to reattach the back cover to the phone.
Before disassembling your device, be sure the battery is charged below 25%. If accidentally punctured or damaged, the battery can catch fire and/or explode; if discharged below 25%, the chances of fire/explosion is decreased.
Be sure to power off the smartphone before beginning this repair process.
Follow the iOpener Heating guide for instructions on using the iOpener.
Was du brauchst
Einführungsvideo
Xiaomi Redmi Note 8 Pro Screen Replacement
Power off the phone by pressing the "Power" button located on the right side of the device.
When the power options screen appears, press the "Power" option.
Press the "Confirm Shutdown" option.
Insert and gently push the SIM card ejector tool (or an unfolded paperclip) into the small hole on the left side of the top edge of the phone.
Press gently to eject the SIM tray.
Remove the SIM card tray from the device.
Use a heat gun to lightly heat the edges of the back to soften the adhesive that connects the back cover to the rest of the frame.
In diesem Schritt verwendetes Werkzeug:Plastic Cards$2.99
Apply a suction cup to the lower portion of the phone's backing and pull firmly to create a crack between the back cover and the rest of the phone.
Insert a Jimmy tool, opening pick, or plastic card under the edge of the back cover.
Use a plastic card or Jimmy tool to slice around the phone's seam, cutting through the adhesive.
Use a Phillips screwdriver to remove the 10 screws from the plastic motherboard cover.
Use a Phillips screwdriver to remove the seven screws from the plastic button module.
Use a spudger to pry up the plastic motherboard cover.
Remove the plastic motherboard cover.
Use the flat end of a spudger to gently pry up the motherboard.
Remove the motherboard.
Use the flat end of a spudger to pry up the end of the large orange flex cable.
Remove the large orange flex cable.
Use the flat end of a spudger to pry up the USB-C assembly from the lower portion of the phone.
Remove the USB-C assembly using a pair of tweezers.
Disconnect the orange flex cable using a pair of tweezers.
Use a pair of tweezers to gently remove the vibrator assembly.
Use a pair of tweezers to remove the small black plastic piece located near the phone's upper lefthand corner.
Use a pair of tweezers to disconnect the small orange flex cable.
Gently remove the assembly with the small orange flex cable using a pair of tweezers.
Use a pair of tweezers to grasp the black plastic strip in the bottom left-hand corner of the battery.
Pull firmly on the black tab and wrap the adhesive strip around the tweezers.
Continue pulling outwards until the entire adhesive strip is removed.
4 weitere Personen haben diese Anleitung absolviert.
